Old 10-28-2006, 08:49 PM   #11 (permalink)
ron1004
Drives: Kia Elan
Originally Posted by j_grote
I found somewhere else on this site to jump pins 5 and 6 on the diagnostics plug, turn the key on, and then proceed to set the fob. I metered between 5 and 6 first and found 11.2 volts with the key on. I did not short them because that would be a dead short. That was dirty info that someone posted.
That's not necessarily "dirty info".
If you connect +12V to one side of a 12V lamp, then measure from the other side of the lamp to ground you will measure a full 12V, then if you then connected the open end of this lamp to ground it would illuminate and would most certainly not be a dead short.
I would trust the poster that said connect 5 and 6 , but can't confirm this, but your method of testing is flawed.
Kia Online Parts and Accessories Catalog
Old 10-29-2006, 01:47 AM   #12 (permalink)
gee6
gee6's Avatar
From Kia Tech info:
Code saving method
Receiver (ETACS module) can save maximum two codes from the transmitter.
(1)
Apply the battery voltage to the terminal "6" of DLC (Data Link Connector).
QED!
My Garage
Old 03-07-2007, 03:37 PM   #13 (permalink)
Britjohn
I used your instructions and they worked fine the replacement remote programmed and worked. But then the other remote I had stopped working, when I programmed that one the other one stopped working. How do i get them both to work?
Britjohn is offline   Reply With Quote
Old 03-07-2007, 04:22 PM   #14 (permalink)
gee6
gee6's Avatar
I think you have to program the second remote before you remove the jumper and exit the programming mode - ie between points 4 and 5 of the instructions given. BUT, I'm not positive about that!
My Garage
Old 03-09-2007, 05:49 PM   #15 (permalink)
jsmith409
Thanks for the info. I programmed my daughters 2004. Took less than 5 minutes. Hers will only except 2 remotes also.
jsmith409 is offline   Reply With Quote
Old 03-10-2007, 11:28 AM   #16 (permalink)
Britjohn
Default Remote keyless entry
Thanks, GEE6, I finally got it worked out. You have to program one right after the other, even if one is already programmed. Also remove the key from the remoteless entry as it doesn't work from inside the car.
So, have both remotes on your hand, connect 5&6, press lock on the first and then immediately press lock on the second.
Proceed as instructed, remove the wire and turn the key off.
Great stuff
Old 03-22-2007, 04:06 PM   #17 (permalink)
pdotek
Drives: 04 Sorento LX
Question
I purchased a remote off ebay and appears to be new. I tried the programming instructions as follows:
1) insert key and turn to on position
2) opened obdII connector
3) jumped pin 5 & 6
4) pressed lock button for one second (the turn signals never blinked)
I have verified that the 2004 Sorento works with the following fob
FCC ID: PLN BONTEC-T016
(attached photo as well)
Anyone have any suggestions? I would hate to have to pay the man to program this thing..
Thanks in advance!
patrick
pdotek is offline   Reply With Quote
Old 03-22-2007, 06:43 PM   #18 (permalink)
gee6
gee6's Avatar
Batteries?
My Garage
Old 03-22-2007, 07:04 PM   #19 (permalink)
pdotek
It appears battery in the remote are good, I get a very bright red light when I press any of the buttons.
Old 03-22-2007, 07:39 PM   #20 (permalink)
pdotek
just to clarify, I am connecting 5&6 with a wire. I have attached a photo and colored the connections red that I am making.
