Old 07-20-2006, 01:53 PM   #1 (permalink)
beyond_help
Default transmission fluid change
i changed my trans fluid today for the first time, took all of a half hour
vehicle, 05 sorento, 5 speed auto, shiftronic, A5SR1 trans
the only fluid you can use is, kia Red-1, $7.02 a quart p/n, um040-ch020
it takes 4 1/2 quarts to fill hot, just pull trans drain plug and refill
beyond_help is offline   Reply With Quote
Old 07-21-2006, 10:16 AM   #2 (permalink)
Benjammin
Benjammin's Avatar
Drives: 2004 Kia Sorento LX 4x4
Gallery: 4
Are you doing the differential at all in the near future? (or have done it recently?) Just curious...
Benjammin is offline   Reply With Quote
Old 07-21-2006, 11:42 AM   #3 (permalink)
beyond_help
i already changed the both diff fluids, the rear is sort of a pain in the butt since the rear end has to be eight inches higher than the front to get the proper amount in, as per Kia service instructions
Old 07-21-2006, 02:13 PM   #4 (permalink)
Benjammin
Benjammin's Avatar
Gallery: 4
I've read the same thing.
Old 07-26-2006, 12:16 PM   #5 (permalink)
Steveo
I've just bought an 04 Sorento with AT, 28K miles. Did I read correctly that the tranny holds 12 quarts but you only need like 4 to "change" the tranny fluid???
Furthermore, is "Mobile DII" as called out inthe manual the same as Dexron 2 and is only Mobile allowed?
Steveo is offline   Reply With Quote
Old 07-26-2006, 12:31 PM   #6 (permalink)
hciaffa
How do you refill it? Meaning where is the refill for the transmission. you don't use the tube that the AT dipstick in????? Thanks
hciaffa is offline   Reply With Quote
Old 07-26-2006, 12:52 PM   #7 (permalink)
beyond_help
fill through the dip stick tube, mine is an 05 which has a different trans then 03 and 04's and uses different fluid, use the fliud specified in the manuel, the amount, 12 quarts includes the converter which you can't drain just change the trand fluid and then do it again a few days later
put in 4 quarts run untill hot and recheck, add to proper mark on dip stick
Old 07-26-2006, 07:08 PM   #8 (permalink)
Goldsuv
I just had my transmission fluid changed by the KIA dealer. It was $140
You saved alot of money.
Goldsuv is offline   Reply With Quote
Old 04-24-2007, 08:21 PM   #9 (permalink)
KWolf
I'm kind of new to the forum with a 2005 @ 15k and was scoping out service info.
Has anyone tried synthetic diff oil or should I stick with the stock stuff?
KWolf is offline   Reply With Quote
Old 04-25-2007, 07:28 AM   #10 (permalink)
beyond_help
either, or what ever you want to use, just make sure it meets or exceeds gl-5 spects and is the proper wt range (80w-90, 85w-90) and is for limited slip use in the rear (some say "for top off of limited slip diffs) read the bottle carefully
synth i think are 75w-90, i think you should be ok with any of the above
just document the change miles and date and recept and amount you put in the rear as per kia spects and raised the rear of the vehicle 8 inches to fill should any warrenty questions arise
