Everybody out there with a clock reset problem do me a BIG favor. I think I'm onto something and I need a bigger sample size. I may have an idea on what's causing the clocks to reset. I don't think it's the clocks, the reset is a symptom of another problem and replacing the clock is a band-aid.
So here goes:
My 2005 Sorento has the headlight-auto-shutoff feature, in case you're forgetfull. If your headlights turn off automatically even if the steering column switch is on, go ahead and leave the headlights on when you shutoff the ignition. Make sure you've set the clock before shuting off the ignition.
Wait your usual amount of time (for a reset). When you start the car, leave the head-light switch ON. Observe the clock, has it reset, or is it still keeping correct time?
My clock reset problems will go away if I leave the head-lights on during ignition. LET ME KNOW! If theory works even on 20% of you out there, then I know I'm right on one of two possibilities and will do further testing and post my results.
