Old 08-27-2007, 12:08 PM   #1 (permalink)
cjford
Default 2000 sephia won't start
we have a 2000 sephia automatic.
the other night hubby was driving home and the engine shut down. after that it would not start. the starter clicks but engine does not turn over. we tried putting a different battery in but still no start. what else should we check?
Julie
cjford is offline   Reply With Quote
Old 08-27-2007, 12:32 PM   #2 (permalink)
Alarmin
Alarmin's Avatar
Drives: Kia Cee'd 1.6 CRDi LS
Gallery: 4
I leeched this from Global Service Way
I hope it helps
Sephia [FB] > 2000 > Engine > 1.8 DOHC
SYMPTOM-RELATED DIAGNOSTIC PROCEDURE
Symptom Guide
No.
1 Will not crank - starter motor does not operate
2 Will not crank - starter motor spins
3 Cranks slowly
4 Generator warning light illuminates with engine running
5 Discharged battery
6 Misfire
Symptom troubleshooting
step Inspection Action
1 Check if engine cranks with fully charged battery. Yes Check charging system.
No Go to next step.
2 Check if battery voltage is suppliedat B terminal.
Yes Go to next step.
No Check wiring harness.
3 Check if battery voltage is supplied at S terminal with clutch pedal depressed (M/T), car in park (A/T), and ignition switch in START position.
Yes Replace starter unit.
No 1) Check starter clutch pedal position switch (M/T).
2) Check transmission range switch (A/T).
3) Check ignition switch. (Refer to Electrical troubleshooting manual)
4) Check wiring harness.
1 Check if drive pinion is pulled out while cranking.
(Click heard when pulled out.)
Yes Remove starter and check flywheel ring gear teeth and starter drive pinion teeth.
No Replace starter unit.
3 Cranks slowly
1 Check if engine cranks normally when fully charged. Yes Check charging system.
No Go to next step.
2 Check starter cable connection for loosensess and corrosion.
Yes Repair or replace connection.
No Check for seized motor armature. repair or replace as necessary.
4 Generator warning lamp illuminates with engine running
1 Check for correct battery voltage at idle.
Specification : 14.1~14.7V Yes Check wiring harness between generator L terminal and generator warning lamp.
No Check charging system.
1 Check charging system. Yes Turn ignition switch ON andcheck dark current as shown.
Dark current : Blow 20mA
No Repair or replace parts as necessary.
6 Misfire
1 Disconnect spark plug wire from each spark plug and check for strong blue spark while cranking. Yes Check spark plug.
If OK, engine electrical system is normal.
If not OK, clean or replace spark plug.
No Check ignition system.
(Institute of Advanced Motorists)
http://www.iam.org.uk
Alarmin is offline   Reply With Quote
Old 08-27-2007, 01:11 PM   #3 (permalink)
ron1004
Drives: Kia Elan
Welcome to the forum.
The fact that the engine died while driving indicates that the voltage dropped too low, and for this reason I would not start looking at the starter motor right now, but the charging system.
I suggest that you jump start it from another car, and when (if) it starts, then measure the charging voltage with the engine running.
If the charging voltage is 13.8~14.2 V , then I would say the battery has gone bad and needs replacement.
Old 08-27-2007, 11:22 PM   #4 (permalink)
1fastkia
and if the battery is tested fine I would say get the alt tested!!
2008 Sportage
10K Hids
Chrome Door Handles
More to come
1993 Honda Del Sol (vtec)
Old 09-05-2007, 12:17 PM   #5 (permalink)
Alarmin
Alarmin's Avatar
Gallery: 4
Julie
Has this been sorted out yet?
Old 09-16-2007, 10:39 PM   #6 (permalink)
kiaracer
kiaracer's Avatar
most likely it's the alternator. if the voltage drops too low the ECU will shut off and that in turn will kill the engine. if it was me i'd get both the battery and the alternator tested.
North Carolina Kia
