Old 03-22-2007, 12:09 AM   #1 (permalink)
Jro__
Default Help With Fuse Location
I have a 98' Sephia, bought the car used First O2 Sensor has been replaced, and the Speed Sensor has been replaced fixed all the lights check engine and o/d off light flashing. My dome light is not blown but is not working I can't figure out what fuse it may be. Is it the fusebox in the left front panel or the fuse box under the hood. Note* Fusebox in front panel has no diagram.
Also does kia sephia's come stock with duel ram air intake?
Jro__ is offline   Reply With Quote
Old 03-22-2007, 03:47 PM   #2 (permalink)
CvGhost
CvGhost's Avatar
Hey bud here are a couple of threads that touch on your od light .....
http://www.kia-forums.com/2g-1998-20...-blinking.html
http://www.kia-forums.com/1g-1993-19...-flashing.html
http://www.kia-forums.com/kia-sephia...nna-shift.html
Btw your fuse box #1 is by your feet on the drivers side and #2 is under the hood like you said. But neither of those will fix your problem. ON my kia when i had it the dome never worked from the day I bought it at 22 miles.
CvGhost is offline   Reply With Quote
Old 03-24-2007, 12:57 AM   #3 (permalink)
drift_king
drift_king's Avatar
Drives: 2001 Kia Sephia
The fuse would be in the inside fuse box. you should first replace the light bulb, then check all the fuses.
the ram air intake does not come stock(aftermarket).
If engine light is flashing, misfire is happening(sparkplugs or plug wires).
If O/D is flashing, then something transmission related.
Dont give up on the car. It's still young...
drift_king is offline   Reply With Quote
Old 03-30-2007, 03:51 PM   #4 (permalink)
Jro__
Smile Fixed
Took all the fuses out and found a blown one so that's fixed. The O/D Light was going off because my speed sensor was throwing bogus readings to the car, and I fixed the o2 sensor but I keep getting bank to lean left side anyone have this problem I haven't changed the fuel filter yet but I have a new one to install any of you think that would fix the problem?
Edit:
Took off air filter tubing from the power flux (which was cracked and split in 3 places) tossed steel pipe with a large cold intake air filter fixed the oxygen problem.
