Replacing rearview mirror with Homelink and Compass - Kia Forum
 2Likes
  • 1 Post By jaredmwright
  • 1 Post By njerald
post #1 of 9 (permalink) Old 04-21-2017, 01:13 AM Thread Starter
Drives: 2017 Kia Niro Touring w/Tech Package
Quoted: 10 Post(s)
With the help of njerald on this forum, I was able to successfully swap out the basic rear view mirror with an upgraded unit off of a 2014 Kia Optima.
This isn't too bad to do if you are inclined to solder and tap into wiring. Mine looks factory and it is really nice to have the garage door opener and as a bonus a compass option. The one thing I didn't think about but really like is the auto dimming feature based on light, it really reduces the headlights in the dark and makes for a much more pleasant driving experience. Highly recommend consider doing this, Kia should make this an option.
I forgot to take before pics, but you can look at your own for those.
Here is the windshield with the cover removed, there are two clips on the front bottom closer to the hood, you can stick a small flathead under to release them carefully, then pry around to pull it off.
The connectory with the black felt wrapping is what you will connect to. It unclips easily.
I pulled apart the wires and connected to the black and blue on the right side (black negative, blue 12V ACC)
2017 Kia Niro Touring w/Tech Package - Pearl White/Black Leather
jaredmwright is offline
post #2 of 9 (permalink) Old 04-21-2017, 01:14 AM Thread Starter
Quoted: 10 Post(s)
Pigtail I used so I can disconnect if the mirror needs removed or windshield replaced in the future.
Here is my harness all tidied up.
These wires are coming from the mirror, the black is ground and the other three power the compass, homelink and dimming feature. I tied the the three wires together to the blue ACC wire above in the harness and black to the black in the harness above.
Mirror wires connected and tidied up.
post #3 of 9 (permalink) Old 04-21-2017, 01:15 AM Thread Starter
Quoted: 10 Post(s)
Wires connected to the harness powering the module on the window
Mirror from 2014 Kia Optima
Any questions, fire away.
md.cousin1 likes this.
post #4 of 9 (permalink) Old Yesterday, 09:58 AM
Drives: 2017 Niro
Quoted: 12 Post(s)
super awesome. what did the mirror cost? any idea if KIA will void the laser weapons warranty now that you've cut into it?
tvmaster is offline
post #5 of 9 (permalink) Old Yesterday, 10:33 AM Thread Starter
Quoted: 10 Post(s)
No idea, but I can remove it if I ever need service easily, didn't cut, only tapped. Not much different than any other after market items that integrate in. It is a very low risk item, if you are concerned you could run a power line to the fuse box, although that is overkill and unnecessary since you are only tapping power not modifying the other components.
Sent from my ONEPLUS A3000 using Tapatalk
post #6 of 9 (permalink) Old Yesterday, 12:18 PM
njerald's Avatar
Drives: 2017 Kia Niro Touring w/Tech Pkg, Blue/Grey
Quoted: 33 Post(s)
The mirrors are available used on EBAY for $40-70 with a variety of functions.
...Homelink Compass Mirror, tinted front windows, chrome window trim and door protectors, Stainless exhaust tip/license plate frames, center console tray, Kia rubber mats w/ cargo mat, mudflaps, LED interior/license plate lights, Sport pedals..
njerald is offline
post #7 of 9 (permalink) Old Today, 11:00 AM
Drives: 2017 Niro
Quoted: 12 Post(s)
any advantage to buying one which was branded for a KIA, or is a generic Homelink kit perfectly ok?
tvmaster is offline
post #8 of 9 (permalink) Old Today, 11:02 AM Thread Starter
Quoted: 10 Post(s)
Just make sure the mount is the same and you like the size and shape of it my opinion. Otherwise shouldn't matter.
post #9 of 9 (permalink) Old Today, 03:02 PM
njerald's Avatar
Quoted: 33 Post(s)
You just need one with a tapered mount. I know Kia/Hyundai mounts are correct.
I would also recommend one with wiring attached which will save you a step.
jaredmwright likes this.
njerald is offline
  Kia Forum > KIA Models > Kia Niro
