'05 Optima Driver Door WON'T Unlock - Kia Forum
post #1 of 8 (permalink) Old 02-10-2010, 02:19 PM Thread Starter
Good Afternoon,
I have been having this frustrating problem for about 2 months now. My driver's side door will not unlock either from the outside or the inside. At least, not consistently. Every once in a while I can get it open with the key but never from the inside if it's locked. I searched the forum and couldn't find any solution. If anyone has any suggestions on how to solve this issue on my own without having the need to take my car to my mechanic or my dealer (hoping to save some $$$$) I would appreciate any assistance.
Thanks in advance
Hollywood118 is offline
post #2 of 8 (permalink) Old 02-10-2010, 02:48 PM
Memorial Super Moderator
pulsar86's Avatar
Welcome to the KIA forums. When you use the remote do you hear the electric solenoid in the door trying to operate at all? If you can hear the solenoid trying to move it most likely is not at fault as they are fairly simple with a single winding and usually are fairly reliable. You will have to remove the trim to check that the solenoid is getting full power supply and that terminals are clean and tight on the solenoid. The main other thing to look for is that the adjusting screws on the activating rods to the lock are tight and that they are not fouling on any thing to stop the solenoid from moving through it's full range of movement to activate the catch and that the mechanism is lubricated..
pulsar86 is offline
post #3 of 8 (permalink) Old 02-10-2010, 03:43 PM Thread Starter
Pulsar86,
Thanks for the reply. Unfortunately, I do not have a remote for the locks. I also probably should have mentioned that when I am able to get the door open, I can successfully lock the door and close the latch on the side and then unlock and use the handle to pop the latch open, both from the inside and outside. It's very mind boggling as well as frustrating as I have to climb through the passenger side of the car to get in and out.
post #4 of 8 (permalink) Old 02-10-2010, 07:57 PM
Sounds like you need to replaced the door latch. I just replaced one today for the same issue. The latch has a return spring on it that may become damaged and will not allow the latch to unlock. Once unlocked the door works properly until locked again then you would not be able to unlock again with out struggling
cdavis is offline
post #5 of 8 (permalink) Old 02-10-2010, 09:29 PM Thread Starter
So is this a part I'd be able to get at a local auto parts store or do I have to get it from a dealer?
post #6 of 8 (permalink) Old 02-11-2010, 04:24 PM
I,m having the exact same problem. It's a real pain!
el-gringo is offline
post #7 of 8 (permalink) Old 02-11-2010, 04:49 PM
+1 on CDAVIS's reply. Definitely sounds like a latch problem. I'm pretty sure this is a dealer only part. They're not to bad to replace, but the door lock actuator HAS to be removed with the latch, and seperated once both parts have been remove together. Be careful of the little plastic clip that secures the 2 parts together at the link rod. It does comes off, just be gentle and use a small pick or screwdriver to remove it.
mattybyzf is offline
post #8 of 8 (permalink) Old 06-20-2014, 10:20 AM
2005 KIA driver door won't open 6-2014
Originally Posted by Hollywood118 View Post
Good Afternoon,
Thanks in advance
6-20-2014 The above message from 2010, talks about the exact same thing that is happening to my 2005 KIA this month. I saw suggestions on how to fix the problem and was curious how "Hollywood118" finally resolved the problem.
If anyone has fixed this problem please reply as I have to deal with this now too.
Thanks.
Hirst2005KIA is offline
