Originally Posted by KOPTIMA01
I have a kia Optima 2001 70,000 miles. It has recently had a rough idle when in drive at a light with check engine light on. No codes come up on computer and i clear it and then the check engine light comes back on. once up to speed the car runs fine. seems to be missing. I have changed the plugs and the wires and the air filter. Scheduled to bring it in to have the timing belt changed.
I had a similar problem after checking all that you mentioned, I found out it there was a hole in the rubber hose connected to the pvc valve, which is located behind the big plastic shell.
