'08 Spectra SX timing belt replacement cost - Page 3 - Kia Forum
post #21 of 36 (permalink) Old 10-13-2013, 03:23 PM
DavesSpectra's Avatar
Quoted: 355 Post(s)
If you can push the AC belt in 1/2" in you are OK..
You said "I think I'm done. I think I'm done. I think I'm done."
You are close... Unlike my poor "Cleveland Browns" the "heart break kids"..
Hope you score at the end of the game...
DavesSpectra is offline
post #22 of 36 (permalink) Old 10-22-2013, 07:48 PM
Drives: 1987 Nissan truck, 1993 Festiva, 2004 Spectra 2.0L,
Very strange. I drove the car to work and back, about a half hour each way, with no problem. Got in the next morning started it and got terrible noise coming from under the hood. Screw it, took the other car to work. When I got back under the hood, the Alt belt tightener was backed waaaaay off and the belt was hardly turning. I would swear it backed itself out, but that's impossible. I guess it was gremlins. I hope that's the last of them.
All I have now, is a whine as I run the rpm up, as if on an old style car, the fan was whining. I dread to think it is the new timing belt tensioner.
Qroger is offline
post #23 of 36 (permalink) Old 10-22-2013, 07:49 PM
Oh, also, Dave; Thanks for all the help and encouragement.
Qroger is offline
post #24 of 36 (permalink) Old 10-22-2013, 10:21 PM
Quoted: 355 Post(s)
If you get the timing belt tensioner too tight the belt WILL whine.
The good news is ...only the top tb cover has to come off to access the tensioner pulley. My 06 was making noise and when I backed off the tensioner the noise went away.
You need it tight enough to stay in the teeth but not so tight as it "sings".
I know that the alternator belt tensioner is only accessible through the right wheel well and I have had mine apart (tensioner bolt and Pulley)..If you don't tighten the bolt that holds the adjustment (threaded bolt) that bolt becomes easy to turn (adjust)..When tightened it no longer is easy... I had to teach myself how it worked and how to adjust it..
Still...you haven't even come close to the $500~$600 charge you would have had to pay.. Mark it up to a new learning curve and smile...
post #25 of 36 (permalink) Old 10-27-2013, 06:23 PM
Hi,
I'm new here, but have been following this thread on changing the timing belts on the Spectra. I have a 2009 LX, with approx. 78K miles on it. And I'm aware I'm driving on 'borrowed time', as I have yet to change the timing belt.
I do plan on doing it myself, with the help of a friend who has changed many timing belts on other cars.
My question: Do I need to replace the tensioner and the idler also, or can I just replace the timing belt? I do plan in checking the water pump prior to doing this, along with A/C belts, but I didn't want to buy an entire 'kit' if it wasn't necessary.
Any suggestions and/or comments are welcomed.
Mark
Mentalmischief is offline
post #26 of 36 (permalink) Old 01-20-2014, 12:00 PM
Drives: 2005 Kia Spectra LX, BMW e34 & e46
Originally Posted by Mentalmischief View Post
Hi,
Mark
Hey Mark, it's always nice to replace items when you have easy access to them (the tensioner, idler, and water pump in this case), however if they absolutely don't need to be replaced you are OK leaving them. When I did my TB I opted not to replace the water pump and pulleys. I inspected them and they were in good shape. Too many times, I've done preventative maintenance and just created more work in the long run (either by stripping a bolt or breaking another part). If something isn't broken, I typically will hold off fixing it***. This is just in my experience. YMMV.
I'll add my experience replacing my TB as well. The original belt made it to about 105K and looked in good shape when I replaced it. I ended up just taking the old belt off and slipping the new one on without moving any pulleys. I counted the exposed teeth between each pulley and made sure they matched *exactly* without going through the process of marking TDC, etc. I even took some pictures before the old one came off. It was my first time replacing a TB, and I must have hand-turned the engine about 30 times before I closed my eyes, held my breath, and turned the key. Risky, yes; Recommended, probably not.
***This only holds true on my Spectra... my other cars are a completely different story
goosefoot33 is offline
post #27 of 36 (permalink) Old 02-26-2014, 06:37 AM
2slow4you's Avatar
Drives: 2005 kia spectra5
I have a 05 spectra5 and I called kia to get an estimate. And for my car it would be $475, parts and labor included. Not bad in my opinion Esspecially having to change around 60-90k miles.
2slow4you is offline
post #28 of 36 (permalink) Old 02-27-2014, 04:44 PM
Quoted: 355 Post(s)
If you have done basic car maintenance you can save your self around $445 by doing the TB yourself..The TB can be gotten from rockauto.com for around $30 for a "GATES" brand belt... While you are at it get the AC belt and a set of NGK spark plugs... Not a bad job ...I've done 3 Spec TBs...The info is in a "sticky" in the Spectra area of these forums... Takes about 3~4 leisurely hrs that you will get to know your Spec more..
We are here to help you if you have questions...
Dave...
post #29 of 36 (permalink) Old 10-08-2014, 01:12 AM
Drives: 2006 Kia Spectra5, 2016 Kia Soul +
couple questions
First, thanks everyone! This thread (and others at this site) are really helpful. I have a 2006 Spectra5. I've never done anything as ambitious as a timing belt, but I've got most of the tools, so I figure I may as well try. With the instructions here and at kiatechinfo, it doesn't appear too daunting. And the money saved will more than pay for a bunch of new tools. :-)
A couple minor questions:
Dave, you said you need two floor jacks for this job. Is that strictly necessary? (I have one hydraulic floor jack now.) Couldn't you simply jack the car, put it on a jack stand (just behind the tire), remove the tire, and then use your single floor jack to support the engine? Or are two needed to support the engine?
Second, is it pretty much standard to replace the timing belt tensioner and timing idler when you do the belt? The reason why I ask is because, on RockAuto, they have two different versions of the tensioner (Gates brand), one for cars built before May 23, 2006 and one for cars built after. Mine was built in May 2006, but I'm not sure of the exact day. The one in the pictures on kiatechinfo looks like the "older" version, but I'm a little unsure.
Thanks!
tmport is offline
post #30 of 36 (permalink) Old 10-08-2014, 07:41 AM
Quoted: 355 Post(s)
tmport...
First WELCOME to kia-forums!
Yes you could use just one jack...
You didn't mention the mileage on the car or "if" the timing belt has been replaced..
The tensioner, idler bearing(s), water pump normally should be replaced every other timing belt replacement...
The timing belt is one weak link on the Spectra the second is a commonly ignored item..
The automatic transmission fluid needs replaced every 30k miles...The transmission was a joint venture design by Mazda/Mitsubishi/Ford and was/is used in many cars...One problem with this transmission is that friction material and metal chips start building up in the fluid and the fluid WILL become thickened and become a goo...plugging up the pumps, valves, passage ways of the transmission... Replacing the fluid removes most of the suspended material and greatly increases the life of the transmission... Valvoline MaxLife transmission fluid is readily available at WalMart and meets/exceeds the manufacturers specs (Diamond III)... Failure to exchange fluid usually ends up causing problems over 100k miles...
BTW... The tensioner changes are minor between the earlier and later 2004.5~2009 Spectras (i've done 2006/2007/2009 Spectras and tensioner on the Spectras is not hydraulic but just a mechanical tension adjustment.. The idler wheel (and it's bearing) attached to the tensioner is the critical part that will fail.
