03 Spectra - Kia Forum
Old 06-26-2012, 01:28 PM   #1 (permalink)
Drives: 02 Kia Rio, 03 Kia Spectra
Default 03 Spectra
My 03 Spectra was running great never had a problem, Washed the motor at the car was and now it is miss firing, has carbon build up on two spark plugs, runs ruff at idle and better at higher rpms, cranks really slow at times like it gets stuck and then it gives, will start with a little gas peddle but not a lot? any help is appreciated, cleaned the injectors, tested the TPS, changed fuel filter checked all connections and fuses???
kgdenver is offline   Reply With Quote
Old 06-26-2012, 11:48 PM   #2 (permalink)
DavesSpectra's Avatar
Well if you got the engine wet and it's mis-firing then you have one/all of these problems...
Bad coil pack(s)
Bad spark plug wire(s)
Bad spark plugs
Rough idle is usually IAC (idle air control) valve. They build up carbon in the throttle body and then they stick causing idle to vary widely and stalling...
Another common problem with "earlier" Spectras is the body grounds. Check the heavy negative battery wire at where it's bolted to the frame/body. It's probably corroded and making a poor connection. Unbolt the wire and scrape the area under it to a shinny /clean condition and then smear silicon grease all over the area to keep water out and then re-assemble it.
DavesSpectra is offline   Reply With Quote
