Oil Change 2007 Spectra EX - Kia Forum
post #1 of 6 (permalink) Old 04-06-2010, 10:10 PM Thread Starter
gemstone's Avatar
Drives: 2007 Kia Spectra EX, 2001 Chevy Impala LS, 2014 Hyundai Accent, 2013 Hyundai Veloster
Send a message via Yahoo to gemstone
The owners manual contains VERY LITTLE information on simple service like an oil change... I normally do my own oil changes on my vehicles... I have not even crawled under this car yet so I have a few basic questions with regards to doing my own oil change...
1.) What is the oil capacity of the engine and oil filter?
2.) What oil weight should I buy?
3.) What oil filter should I buy?
4.) Where is the oil pan drain plug located?
5.) Where is the oil filter located?
Thanks!
Go Mark Martin!
gemstone is offline
post #2 of 6 (permalink) Old 04-07-2010, 10:35 PM
Drives: 08 Sonata LTD 3.3, 10 Dodge 1500 Hemi, 95 Taurus GL, 09 Sonata GLS 2.4
Drain and fill is listed as 4.23 US quarts. You going to crack open a 5th bottle regardless, so I would pour in 4-1/4 quarts, start the car to load the new filter, shut it off and check the dipstick. Add as needed. Last time I think it was close to 4-1/2 quarts with new filter.
5W-20, 5W-30 and 10W-30 are all specified as acceptable viscosities. Unless you are driving under extreme conditions, I would stick with the grade that came in the engine new, 5W-20. Use an API certified brand, grade SJ, SL or higher (they are pretty much all currently grade SM).
OEM. Hyundai/Kia 26300-35503 spin-on canister.
Back side of oil pan towards the crankshaft pulley end.
Opposite side from the plug near the crankshaft pulley.
Ken99 is offline
post #3 of 6 (permalink) Old 04-08-2010, 01:02 AM
Memorial Super Moderator
pulsar86's Avatar
Do as Ken99 has said and you can't go wrong. I have a 2005 Cerato [ mechanically the same as your car], if you can get the car up a little off the ground you can remove and replace the filter without having to remove the splash tray under the car, just don't burn yourself on the exhaust , it runs close by the filter. If your can run the car onto some wooden blocks around 3-4 inches thick it gives you enough height to work ok. The amount of oil is 4Litres with filter in metric I usually add 3.5L start the car briefly to fill the filter, wait a little while for things to settle, and then add the rest slowly and keep checking the dipstick as I go to make sure I don't overfill.
pulsar86 is offline
post #4 of 6 (permalink) Old 04-08-2010, 01:16 AM
Anyone that does DIY oil changes or other maintenance and minor repair needs a pair of these:
Amazon.com: Blitz Rhino Ramp 8000: Automotive Amazon.com: Blitz Rhino Ramp 8000: Automotive
Yes, I know these are not handy for wheel-related work, jacks and stands are needed for that. Who knows? maybe Amazon delivers in Oz land...or is that Aus Land? Now I really do sound like an ugly American.
Ken99 is offline
post #5 of 6 (permalink) Old 04-09-2010, 10:01 AM
DMZ
Drives: 2006 Kia Spectra EX
+1 on the Ramps. It is nice to be safe and have some room to work.
DMZ is offline
post #6 of 6 (permalink) Old 04-10-2010, 07:56 AM
Premium Member
1fastkia's Avatar
Quoted: 16 Post(s)
My 06 spectra I only used 4qts. My sportage with the same engine only uses 4qts also.
1987 Mazda RX-7 GLX
The Old
1fastkia is offline
