Old 06-30-2008, 08:47 PM   #1 (permalink)
Choncer
Choncer's Avatar
Default Did i miss any vacuum tubes?
K, so today i pulled out all the upper ends of the stock intake and put in a short ram. I notice at stop lights that i get a vibration in the brake pedal, but only when the A/C is on. I'm curious if there is perhaps a vacuum tube that i was unable to reach in the lower structure of the intake, or possibly the new intake has the idle kinda screwy, and the addition of the A/C compressor is just more than the idle is "comfortable" at.
Take your shots.
::EDIT::
I didnt remove the mass air sensor, so rule that out of anything you were thinking.
Choncer is offline   Reply With Quote
Old 06-30-2008, 09:06 PM   #2 (permalink)
KIAZILLA
KIAZILLA's Avatar
There is only one vacumn line that I know of that connects to your short ram. You can also try disconnecting your battery for a couple of minutes. It clears the ECU, then hook it back up and it will adjust for any airflo differences.
KIAZILLA is online now   Reply With Quote
Old 06-30-2008, 09:15 PM   #3 (permalink)
Choncer
Choncer's Avatar
already pulled the battery and reinstalled when i was looking for a way to pull out the rest of intake.
Old 06-30-2008, 10:16 PM   #4 (permalink)
Metal4TheMasses
Metal4TheMasses's Avatar
Drives: 2006 Spectra 5
You're probably rubbing on a fluid line. If you have the K&N intake you might be rubbing on a small 90 degree angle metal line. I had the same problem but then realized after taking my intake on and off multiple times a small rub mark on what I think is the brake fluid line. If you position it up a little more you won't have the problem. I was pleased to find that it did the trick. When I installed my intake I thought that I might have accidentally knocked my throttlebody and messed up the tension.
Silver 2006 Spectra5
K&N Short Ram Intake
Front Sway Bar
Falken Ziex ZE 912's
http://www.cardomain.com/ride/2411436/1
My lug nuts require more torque than your VTEC makes.
Metal4TheMasses is offline   Reply With Quote
Old 06-30-2008, 11:49 PM   #5 (permalink)
Choncer
Choncer's Avatar
That could quite possibly be it, but i dont think it would explain only happening when the A/C's on.
Old 07-01-2008, 04:28 PM   #6 (permalink)
stetsonboy87
Drives: Kia Spectra SX '06
Thumbs up
hey, buddy, i made my own intake, and it did that same exact thing for a couple of weeks. someone told me that it has something to do with "resetting the computer" to the amount of air coming in.!
stetsonboy87 is offline   Reply With Quote
Old 07-01-2008, 06:41 PM   #7 (permalink)
KIAZILLA
KIAZILLA's Avatar
Check all the coupleings to make sure there are no airleaks, especially where it mounts to the throttle body. I have had a K&N sri for a year and a half with absolutely no problems.
