Question on replacing the brake proportioning valve - Kia Forum
post #1 of 9 (permalink) Old 02-26-2008, 01:16 PM Thread Starter
I have a leaky proportion valve on my 03 spectra.. purchased new one at Kia.
We can change it out, but my haynes does not give any info. on this proceedure.... And I have read all the chapters on brakes.
can it be as simple as..... removing the lines, then the valve, installing the new valve and reconnecting the lines ?
I would think that the lines would need bleeding after changing it out.
Am I correct?
any info would be great.
Thank you
sheryl is offline
post #2 of 9 (permalink) Old 02-26-2008, 02:57 PM
cmhj2000's Avatar
Drives: 09 Cobalt
cmhj2000 is offline
post #3 of 9 (permalink) Old 02-26-2008, 03:08 PM
Drives: KIA SPECTRA 02 SEDAN
Am I correct?
Thank you
Yes, to replace the valve just remove the lines, replace the valve itself, then bleed the brake lines. Your Haynes Manual says how to bleed your brake lines, i have it too and it says how on the brakes section. If you cant find it let me know ill help you further. By the way, the Kia tech info website ( http://www.kiatechinfo.com/viewer/de...asp?group=shop ) also has a guide on how to bleed your brake lines. Select your car and go to Brake System> Brake System > Repair Procedures , air bleeding is the second topic.
My gimped Spectra!
beingpr is offline
post #4 of 9 (permalink) Old 02-26-2008, 05:37 PM
I see the repocedure but you have to look under the brake line replacement. . .
1. Make sure the brake fluid level in the reservoir is at the MAX (upper) level line.
2. Have someone slowly pump the brake pedal several times, and then apply steady pressure.
3. Loosen the right-rear brake bleed screw to allow air to escape from the system. Then tighten the bleed screw securely.
4. Repeat the procedure for each wheel in the sequence shown below until air bubbles no longer appear in the fluid.
Right rear first, left rear second, right front third, left front last.
krceynar is offline
post #5 of 9 (permalink) Old 02-28-2008, 04:05 PM Thread Starter
Thanks to all.... I figured that was the way it had to be done
sheryl is offline
post #6 of 9 (permalink) Old 01-29-2015, 12:23 PM
I need to replace the proportioning valve on 200 Kia Sephia. Can you give me directions?
hollymart is offline
post #7 of 9 (permalink) Old 01-29-2015, 02:36 PM
cobra259's Avatar
Quoted: 364 Post(s)
I doubt any of them are still around this site, or even own a Kia any longer, being the thread is 7 YEARS OLD.......
Start a new thread many more people will see it.......
cobra259 is offline
post #8 of 9 (permalink) Old 09-05-2016, 02:23 PM
Drives: 04 rio
Hi guys, I'm doing the proportioning valve replacement on my 04 rio. Looks like the same valve. I did something stupid- did not pay attention to the orientation when I pulled it off. The thing looks symmetrical except for some down arrows on one side.
I think that the arrows should face out.. So that people can see them. Can anyone confirm this for me??
billabob1234 is offline
post #9 of 9 (permalink) Old 09-05-2016, 04:28 PM
Loyale 2.7 Turbo's Avatar
Drives: 1985 Subaru Loyale (wagon), 2000 Kia Sephia (sedan), and 1969 Mercury Comet (coupé)
Quoted: 134 Post(s)
The arrows usually point the proper way of Flowing, so the Brake Fluid shall flow following the direction pointed by the arrow; it doesn't matter if said arrow ends visible on the engine bay, or facing the firewall.
Kind Regards.
Loyale 2.7 Turbo is offline
