speaker rattle
I had the same problem with my 07 Spectra. I did actually take it into the dealer, and they blamed the noise on some loose pens I had in the door pocket. Funny thing is, the pens were only there for a few days, and the rattle had been there for a few months. Go figure! I think they simply didn't want to fool with it. My husband and I took the door panel off and removed the speaker from the door, and still it rattled. We found that it was the speaker casing, around the outer circle, it had come unglued, or maybe was never glued in the first place. We just glued it together and it worked. No more noise. Taking the door panel off was the tricky part. There are several screws that need to be removed. A few near the door handle, under a cover that has to be removed with a very thin flat head screwdriver, or perhaps a file. There are a few more on the side of the door, under the "caps", and a few more under or inside of the armrest. The rest of the panel just pops off and on. It is such a relief to finally have this fixed. It was so annoying!
