2003 Kia Sedona Timing belt / valve problems - Kia Forum
Old 10-27-2012, 08:45 PM   #1 (permalink)
Drives: 03 Kia Sedona
Default 2003 Kia Sedona Timing belt / valve problems
I recently replaced my timing belt and when I started it up a piece of plastic broke off the cover and caused the cam to jump six teeth. I reset belt but now I get p300 p303 and p 305 codes. I suspect bent exhaust valves. I am going to replace the cylinder head. Does this sound like my valves are bent?
doug68 is offline   Reply With Quote
Old 10-29-2012, 03:59 AM   #2 (permalink)
tafisama's Avatar
Drives: Kia Carnival
Hie,which belt did you replace.The main belt or the slave belts.?Is the car running smoothly or rough.Having the belt jumping six teeth is scarey though.Did you remember to fit the belt tensioner.
tafisama is offline   Reply With Quote
Old 10-31-2012, 01:19 AM   #3 (permalink)
Drives: 2004 Carnival, 2.5L KV6 / GV6 / K5 engine
tafisama, as Doug is from the US I think you'll find he's referring to the 3.5 litre V6 3.5D engine, which does not have the 'slave' (rear) timing belts that you have on your 2.5L K5 engine.
PeterBlue is offline   Reply With Quote
Old 11-01-2012, 05:18 PM   #4 (permalink)
engine compression test & hand rotation fairly easy to do.
KV6 petrol engine variant.
Conglomerate is offline   Reply With Quote
Old 11-03-2012, 04:27 AM   #5 (permalink)
reset timing. same prob. guess teardown replace cylinder head. when replacing head anything i should know ? never replaced head on kia before. poor thing only has 85k on it.
Old 11-03-2012, 04:30 AM   #6 (permalink)
was standard belt change. just bad luck. am capable of doing. just need little help on reinstall
Old 11-03-2012, 04:33 AM   #7 (permalink)
still p300, 303,305. head gone most likely. ran great befoehand
Old 11-03-2012, 04:34 AM   #8 (permalink)
just to remind is a 3.5 us model
Old 11-03-2012, 04:35 AM   #9 (permalink)
appreciate all input. thanks.
Old 11-04-2012, 09:10 PM   #10 (permalink)
What actually 'broke-off the cover'? I'm struggling with how something broke-off and 'caused the belt to jump'. There is a sensor that sits under the cover....is this what broke-off? If the sensor is out of commission, I'm guessing it could throw those codes. How is the car running now? The codes are obviously misfire codes, so it should be pretty obvious if engine is running rough or misfiring. It is an interference engine, so if the belt jumped 6 teeth you may have damaged some of the valves. Although hard to say, I had mine jump 4-5 teeth once when the tensioner stopped working and it did not cause any damage (car still running great). Did it jump on both banks or just one?
If car is indeed not running right, would start with a compression test as suggested here. I never had to replace the head on the KIA, so don't know about any pitfalls. But it looks pretty straight forward. Hopefully it is limited to the valves and not piston crowns. Good luck.
Gidner is offline   Reply With Quote
