Vacum pipes - Kia Forum
post #1 of 23 (permalink) Old 10-05-2012, 05:47 AM Thread Starter
Drives: Kia Carnival 2.5 V6 2002 model
Default Vacum pipes
can anybody help me with a diagram for the vacum pipes on a Kia Carnival 2.5 V6 automatic 2002 model
Daniel Malan is offline
post #2 of 23 (permalink) Old 10-05-2012, 06:21 PM
Drives: 2004 Carnival, 2.5L KV6 / GV6 / K5 engine
Hi Daniel, Are you talking about the various pipes that connect to the surge tank on the 2.5l engine?
PeterBlue is offline
post #3 of 23 (permalink) Old 10-11-2012, 10:38 AM Thread Starter
Default urgent help needed PLEASE
hi good people is there anyone out there that can assist me please.
I have a Kia Carnival 2.5 V6 petrol for wich I need a diagram for the vacuum hoses and for the water pipes on the motor
post #4 of 23 (permalink) Old 10-11-2012, 10:43 AM Thread Starter
yes i am can you help ?
post #5 of 23 (permalink) Old 10-11-2012, 07:21 PM
Not a diagram, but if you go here, where I have some detail on changing the rear sparkplugs (which requires removing the surge tank if done from above), there's a photo that points out the approximate location of the lines.
In summary, there are four lines connected the surge tank:
1. The brake booster vacuum line at the rear of the tank.
2. The purge line for the fuel evaporative emissions canister (which goes via the purge solenoid assembly to the evap. canister on the right).
3. The crankcase vacuum scavenge line which then splits to the right and left camshaft covers,
4. The thin manifold pressure compensation line running from near the throttle body to the injector fuel rail pressure regulator.
Is that what you are after? Can I ask what's behind the question?
Last edited by PeterBlue; 10-19-2012 at 02:52 AM. Reason: Updated 3. with better description
post #6 of 23 (permalink) Old 10-11-2012, 10:08 PM
Hi again Daniel,
On vacuum hoses, I did respond to your post above for info on the connections to the surge tank. There's no diagram as such for the vacuum system that I can see in the workshop manual I have on the 2.5l V6 model.
On water pipes, there no diagram in the Cooling System section either and not a lot of detail on the full circuit. Can you give some more detail on what you are after here? Are you after just the cooling system related connections to the engine? (There are also coolant pipes running to the front heater and down the back to the rear heater, air purge pipes that are technically part of the coolant system, etc). Happy to answer specific questions by looking at mine. (It is a 2004 model, but I don't think there's substantial if any difference).
Cheers,
Peter
post #7 of 23 (permalink) Old 10-12-2012, 02:48 AM Thread Starter
Hi Peter
many thanks for your reponse. there are toe places for vavuum pipes on the back tappit cover and two on the front tappit cover i need to find out where they need to be connected to
Cheers
Daniel
post #8 of 23 (permalink) Old 10-12-2012, 08:00 PM
Peter has just about nailed the response
Look for one of my earlier posts - it had the engine manual.
That has some pictures identifying everything - connection ID wise.
Not much in the way of hose routing though...
The nylon tube goes from one side of engine heads to the other.
Its rubber hose ends are usually brittle & cracked - replace if necessary)
Connects onto front (drivebelt end) hose stubs- and tees into stub atop throttle body near throttle wire connection.
The rear (air filter end) cylinder head/surge intake stubs connect to the stubs atop throttle body closer to air filter.
And you also have the brake vacuum hose as well.
You never take any pictures before dismantling?
Or did you inherit a broken down job?
You also asked about the coolant connections.
You fine with them now?
Be wary of the brittle plastic fittings going into engine- don't swing on 'em
Crack and leak easily...
KV6 petrol engine variant.
Conglomerate is offline
post #9 of 23 (permalink) Old 10-13-2012, 12:33 AM
Daniel, here's a photo of the two breather connections from the (visible) camshaft cover.
The nearer one (i.e. towards the front of the engine) connection goes to the T-piece you can see just above the inlet manifold side of the surge tank, and from there to the connection you can see on the top of the throttle body, on the surge tank (vacuum) side of the T/B. (The other side of the T-piece goes to the corresponding connection on the other bank's camshaft cover).
The other connection on the camshaft cover goes to the 2-way connection on the top of the throttle body that's on the air cleaner (atmospheric pressure) side. And the other hose on that connection goes of course to the corresponding connection on the other bank.
HTH.
Did you need some input on coolant connections?
Cheers,
Peter
post #10 of 23 (permalink) Old 10-13-2012, 12:45 AM
Ahh didn't refresh & see Conglomerate's reply before posting above, so some overlap. The photo should help with routing.
@Comglomerate, a related question for you - where are the PCV valves on the GV6/K5, I assume under the camshaft covers?
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
