2003 Sedona Starter Removal - Kia Forum
post #1 of 8 (permalink) Old 05-06-2010, 05:36 PM Thread Starter
Drives: 2003 Kia Sedona Ex 3.5L V6
Question 2003 Sedona Starter Removal
Trying to remove the original starter motor (burnt). I've managed to remove the bolts for the heat shield, but unable to removal the head shield. What do I do next?
Thank you for your expertise!
djtimster is offline
post #2 of 8 (permalink) Old 05-06-2010, 06:35 PM
Did you remove the 10mm nut at the end of the heat shield??? There are 2 10mm bolts on the front and the 1 10mm nut that hold the heat shield on. Then the shield should slide off toward the exhaust manifold.
cdavis is offline
post #3 of 8 (permalink) Old 05-06-2010, 08:16 PM
Drives: 2006 Sportage
like cdavis said, 3 fasteners in total. Sometimes its snug pulling the cover out but it does come out.
ESKORT27 is offline
post #4 of 8 (permalink) Old 05-06-2010, 08:49 PM Thread Starter
Red face
I've managed to take the 3 fasteners off. So the shield is loose. I tried unsuccessfully to use a rubber mallet to get the darn thing off.....no success. Twist, turn, pry.....no remedy.
My next option, I thought, maybe if I remove the 2 starter bolts...I can find some room to wiggle it loose. Still unable to remove shield and starter.
If I continue to fail, do you recommend that I remove the exhaust pipe so I can remove the shield and starter?
Another question is how do I remove the 2 wire connectors, I fear I may damage them trying during removal
Thanks for your continued help!
post #5 of 8 (permalink) Old 05-06-2010, 09:00 PM
try loosening the starter bolts, it may give you enough room to get it out, like i said, its tight. There should only be a single wire connector on it, it should have a small tab that you push down then pull out and the other wire is the battery cable. Try to avoid removing the exhaust, it opens up a can of worms.
ESKORT27 is offline
post #6 of 8 (permalink) Old 05-06-2010, 11:15 PM Thread Starter
Thumbs up
With your help and a little more persistence.....I was successful in removing the shield along with the starter! Wish me luck on the replacement install.
Thanks!
post #7 of 8 (permalink) Old 05-13-2010, 09:53 AM
hi timster
this has happened to me now, going to try and get mine off tomorrow, how di your re fit go , did you use the kit of e bay and was it succesfull?
thanks
earlgrey is offline
post #8 of 8 (permalink) Old 08-05-2012, 01:06 PM
thanks for posting this reply i needed it that shield is a little bugger
heaven55 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
