Originally Posted by nojoke1981
I did look at it with a buddy of mine, but he was not familiar with Kia's. He told me it may be the timing belt, or a rev limitor issue or rev limitor sensor issue, but does not think it is a rebuild. Does this sound possible. If so any idea how much it would cost to have the timing belt changed? The noises it makes at high rpm is loud. The pinging/knocking does not sound good. Any ideas would be appreciated. It is a little odd to me that it only does it at high rpm and not at idle or in between.
Sounds like it is starving for fuel or the oxygen sensor/s have failed.
Replacing the fuel filter would be a good start.
Not sure on the O/S models but it is under the floor just in front of the second row of seats in the Australian model.
It is accessed through the floor by pulling back the flap of carpet there
The filter is contained inside the fuel tank in a plastic housing that needs to be gently unclipped to get at the fuel filter.
