I have a 2003 Kia Sedona. It's been working fine until today when driving home we noticed the heater blowing cold air in the rear of the van, then the engine temp started to redline. We pulled over and turned off the car for a few minutes. When starting up again, noticed the engine was running loud but the temp. gauge went back to normal. Then heat stopped working completely and air conditioning fan and light would not turn off. After driving a few minutes the gauge stared to redline again. The air turned off and the gauge came down a little but not much. When we arrived home (which was only 5-6 minutes after this started happening), we checked the coolant levels (even though we check and fill these regularly and had just done so a couple of weeks ago) and noticed the engine coolant is very low. Strange, because it was just done and we haven't noticed any leaks. Topped up the coolant and started up the van again, same things happening and the coolant disappeared by 1/4...no visible leaks anywhere! Radiator is cool, no smoke, no discharge anywhere....could it be the thermostat stuck open or closed?
HELP! My warranty just ran out last month, of course!
