Old 10-11-2008, 05:58 AM   #1 (permalink)
bopbo
Drives: 06 Grande Carnival
Default Loss of power
G'Day
My friend has an 03 Carnival that has what i think is a fuel pump/filter problem.
She had a problem where the car would lose power to the point of having to pull over, wait a few minutes then drive away, it seemed to be worse when tank was 1/4 full, they had been using petrol from a suspect source (they have stopped using it now) so i changed the fuel filter and cleaned the course filter, both VERY dirty.
All was well on the next trip aprox 350Km but on the next fill the problem has started again.
I today pulled the pump/filter assy expecting to see the course filter full of crap but all 'apeared' ok
We put injector cleaner in, went for a drive and all seemed fine for about 30 minutes at highway and local speeds then when near home it would not go faster then 40Kph, the tank is about 1/4 full
It idles fine (no missing) it will rev freely sort of, but makes not much real power
My thought is maybe there is somthing up with the fuel pump but i donot want to just start trowing parts at it.
Any other thoughts
Brian
bopbo is offline   Reply With Quote
Old 10-12-2008, 03:38 PM   #2 (permalink)
93fxdl
just a shot in the dark but try checking the filler cap breather or next time it looses power try taking off the cap. might not be the cause but dosent cost anything to check
i once heard of a car with a blocked breather and it collapsed the tank!
ttfn glenn
ps if the fuel you used had crap in it could it have some water aswell if so i seem to remember a splash of methylated spirit added to the fuel will help but do some more research before trying this as i cannot be sure this info is correct
Old 10-12-2008, 04:46 PM   #3 (permalink)
bopbo
Thanks for the breather tip, i wil give it at try as to the water the injector cleaner claimed to absorb water, but i assumed water would more constant not just after 1/2hour
I recall the metho and water trick as well and am pretty sure it works
Brian
Old 10-18-2008, 06:33 AM   #4 (permalink)
bopbo
Ok,
The problem is still there when the fuel cap is loose enough to allow air in which eliminates the breather cause.
Could it be the pump getting too warm causing this as the problem seems worse when the tank is less than 1/4 full and after driving for a while, although i saw it do it today after driving for 10 minutes, but today was warmer than it has been 31C (87F)
Any other sugestions?
Brian
Old 12-16-2008, 02:58 AM   #5 (permalink)
bopbo
Update,
She took it to the local kia dealer, and they suspected it was either the filter or pump. Apparently the fuel has a three step filtration system, 1, the course filter at the bottom. 2, a finer filter inside the tea bag course filter. 3, the fine paper? filter encased in plastic that surrounds the pump.
It was the medium filter inside the 'tea bag' that was causing the problem, apparently they have some type of 'tumble cleaner' that they put the filter through, problem all fixed.
Brian
