Old 08-19-2008, 08:30 AM   #1 (permalink)
ziggy95
Default Oil leak/Oil change
Hi Everyone, have done a search but couldn't find any info, so here goes:
Sedona 04 LE diesel engine
I appear to have an oil leak as there's slowly built up a black mark on my drive underneath the engine. Due to funds I haven't been able to get the car in for a service for months now, so want to change the oil and oil filter myself to hopefully fix the problem.
As a non-mechanic, is this an easy thing for me to do ?
If so a step by step guide would be appreciated along with what make of oil & filter and also how much oil I would need.
Got to make a 200 mile journey shortly so would like to get this change done before I go
This job used to be dead easy on old Fords and the like but this engine seems so squashed in and big I don't want to take on more than I can chew, BUT I am skint at the moment.
Thx in advance
Zig
ziggy95 is offline   Reply With Quote
Old 08-24-2008, 04:24 PM   #2 (permalink)
93fxdl
if you could do a change on an old ford then you can do a sedona the filter is at the front of the engine but a bit of a fiddle to get at since funds are tight get the filter from your nearest motor factor (look in yellow pages) just tell them what you want for what car and they should see you right
ps would advise changing air and fuel filters at the same time
ttfn glenn
pps a way of tracing oil leaks is to wash the engine let it dry then dust it with talcum powder then run it as the leak starts the talc will stain black making it stand out against the white
Old 09-03-2008, 04:26 PM   #3 (permalink)
Highlander
Drives: 2004 2.9CRDi Sedona.
Smile Oil & Filter change. What oil??
Alright,
Your engine takes between 8-9 Litres of oil. Kia recomend 10w-30 grade oil to ACEA B4 standard. I couldn't get oil of this spec locally so phoned Kia in Inverness they said they service these cars with semi-synthetic 10w-40 Mmmm, phoned Kia in Paisley they use Mobil1 10w-30 or 5w-30. Who are we to believe when the dealers don't sing from the same sheet.
I popped along to my local Morrisons Petrol station and bought Texaco Havoline 10w-40 ( Meets ACEA B4 spec ) and it was very very reasonably priced.
You will manage no sweat just be sure not to overfill and dip your oil when the engine is hot allowing for a settling down time.
Highlander.
Highlander is offline   Reply With Quote
Old 09-04-2008, 09:09 AM   #4 (permalink)
93fxdl
when i did my oil and filter i could only squeeze just over 5 litres into mine as for which oil to use i got mine at the factors i got the filter from cant remember the spec but it was a comma semi synthetic
ttfn glenn
Old 09-14-2008, 07:54 AM   #5 (permalink)
tigertc1
Hi I would put a new copper washer on the sump drian bolt, as well to stop oil leaks
tigertc1 is offline   Reply With Quote
Old 11-19-2008, 07:39 AM   #6 (permalink)
ziggy95
Hi everyone,
Thx for the responses, haven't been able to get back on until now as my computer died.
OK update is that I decided against the 200 mile trip just in case and have been using the car only for 5-10 mile local journeys (about 1 a week). I really need to get this done ASAP as the leak appears to be getting worse and I can see it dripping out when I stop the car.
It appears to be coming from a round cylinder at the bottom of the engine (assume that's the oil filter ? ) I suppose if that's gunked up the oil is forcing it's way out from the seals of it ?
Does the car need to be jacked up or can I get under to do the job without doing this as I don't have any jack other than the one that came with the car ?
The oil I've been topping up with (as recommended by local garage) is 10w40 synthetic based acea a3/b4. Is that OK ?
On a seperate note, I also need to replace my front brake pads. I did this once on my old Maestro so again, I need to ask if it's fairly straightforward to do please.
Thx everyone
Old 11-20-2008, 04:32 AM   #7 (permalink)
93fxdl
if the round cylinder is at the front of the engine it most likely is the filter i did have mine start to undo so make sure it is tight as for the brakes similar idea to a maestro but of you search the forum you will find several threads on doing the job
pete b if i remember correctly did a full disaster story with lots of pictures
ttfn glenn
Old 11-26-2008, 08:55 AM   #8 (permalink)
ziggy95
Hi again,
Quick update, I had the oil warning light come on so checked the oil (before going anywhere) and couldn't see any oil in the system on the dipstick. I checked the oil filter and it was coming undone, so I've screwed it back tight by hand, topped up the oil and will get a new oil filter.
2 questions please.
i. I've read that it's the gasket that wears that causes the oil filter to come undone, when you get a new oil filter does it come with a new gasket ?
ii. I assume as my oil was so low (unreadale on dip stick) that by re-filling, I've basically done an oil change, i.e the oil had all dripped out and has been replenished with new. Is this correct ?
Thx
Old 11-27-2008, 02:18 PM   #9 (permalink)
93fxdl
1 the filter will come with a new rubber sealing ring
2 no you have replaced some of the oil but all the sludge and rubbish is still in the bottom of the sump
ttfn glenn
