Originally Posted by zylax
Hi again, the warranty has recently run out, the car has only done 60k and yes ive had the problem from new. some days it dosn't ping but on others it dose. The worst i have heard it is on a very hot days, it sound like a jar full of marbles when you try to accelerate. most of the other time you can just notice it. And as usual all i seam to get is the run around from kingswood kia service department.
OK, have you got the service dockets that state the problem and the process they went through?? The warranty period is not valid if there is a specific problem recorded and still unresolved. Which this sounds a lot like.
I think there must be another dealer close to you in sydney. Make an appointment with the service manager, sit down with him and go through the times you have asked for it to be checked and the result. ie. Still not fixed. If there is no joy tell him you will go to another dealer as they seem unable to fix the problem.
There are so many possiblities from the timing belt maybe put on wrong, to a vacuum leak, to wrong details on the ecu to problem with fuel delivery.
KIA are able to check the car out and watch what is going on with it while it is being driven. I would have thought the check engine light would have come on with a misfire, but obviously the knock sensor is able to retard the timing sufficiently to stop that from happening for too long. The fact it is worse on hot days could mean either fuel or air problems, rather than spark.
So I guess the ones to ask the manager seeing it has been there from new is
1. Have they thoroughly checked the injectors for blockage
2. Is the fuel regulator to specification and fuel pressure ok.
3. Is there a leak in the intake somewhere after the MAF.
4. Is the MAF just plain faulty.
All this should have been done already by them, but ask them to confirm what actions have been taken to remedy the situation, and this as I said should all be performed under their warranty as they have not yet fixed a warranty issue that was documented during the warranty period.
Let us know how it goes.
