Old 04-22-2007, 11:10 AM   #1 (permalink)
dlando
dlando's Avatar
Drives: 2005 Sedona
Question Alternative oil filter for Sedona?
I'm searching for an larger capacity oil filter that will fit on the Sedona instead to the fram ph3593a? The factory and after market filter are a little limited in size for the V6 engine any info would be helpfull.
2005 Kia Sedona LX
ABS, DVD Player
USA California
dlando is offline   Reply With Quote
Old 04-30-2007, 02:54 PM   #2 (permalink)
rob_fed
Gallery: 25
You might want to stick with the stock filter, or at least have one on hand if you have engine problems. Heard that Kia service at the dealer might give you a hard time if non-OEM filter is not in place.
But you are right the PH3593A is physically very small. The stock one is larger in diameter.
You could always get a perma-cool adapter to relocate the filter, this kit uses a PH-1 (common Ford V8) filter. I was looking to do something like this, but lower engine belt and pulley may interfere with the adapter hose routing.
Also, be careful in just finding a larger replacement filter to screw into the original location, internal valving of the filter may not work with the Sedona motor. Also, diameter of the seal ring must be the same.
rob_fed is offline   Reply With Quote
Old 05-10-2007, 10:04 PM   #3 (permalink)
dlando
dlando's Avatar
Drives: 2005 Sedona
Thanks for the advice, but I think it would be best to stick with the small filter, instead of the adapter. Our local Walmart sells them for $2.50 each and they comply with the warranty.
2005 Kia Sedona LX
ABS, DVD Player
USA California
Old 05-11-2007, 02:40 AM   #4 (permalink)
cpapashley
Isn't that engine a mitsubishi based engine? Probably the one in the Mitsubishi Diamante, might be worth checking out anyway.
cpapashley is offline   Reply With Quote
Old 05-12-2007, 11:46 AM   #5 (permalink)
Dwight Barnett
Drives: 2006 Sedona & 2006 Sonata
Smile
Other filter brands available as follows(all are with o'rings)
Carquest #84061
Champ #P972
Hyundai & Kia # 26320-3C100
Luber-Finer #P672
Napa #7061
Performax #PO-164
Purolater #L35610
Securty 1 #CH=9999
Wix #57061
Fram # CH9999
Fram has a special this week in Michigan at Murry's Auto stores at 2 for $7.00
Dwight Barnett is offline   Reply With Quote
Old 05-12-2007, 11:04 PM   #6 (permalink)
dlando
dlando's Avatar
Drives: 2005 Sedona
Carquest #84061
Champ #P972
Luber-Finer #P672
Napa #7061
Performax #PO-164
Purolater #L35610
Securty 1 #CH=9999
Wix #57061
Fram # CH9999
Nice Info Thanks
2005 Kia Sedona LX
ABS, DVD Player
USA California
Old 05-12-2007, 11:05 PM   #7 (permalink)
dlando
dlando's Avatar
Drives: 2005 Sedona
I never knew will look into it
2005 Kia Sedona LX
ABS, DVD Player
USA California
Old 05-18-2007, 10:53 PM   #8 (permalink)
dlando
dlando's Avatar
Drives: 2005 Sedona
Update:
I will try this filter on my next oil change
Fram PH2849A
Product Type Full-Flow Lube Spin-on
Anti-Drain Valve YES
Product Height 4.92"
Product I.D. 20mmx1.5mm Th'd
Product O.D. 2.98"
Relief Valve Setting PSI 12
it should have enough clearance to the frame
2005 Kia Sedona LX
ABS, DVD Player
USA California
Old 05-19-2007, 04:40 AM   #9 (permalink)
cpapashley
Keep us updated on how it goes.
Old 11-20-2008, 12:05 PM   #10 (permalink)
CitadelBlue
The 2008 V6 Hyundai Santa Fe uses the same filter. I was thinking of using Mobil 1 oil to extend the time between oil changes and was wondering if any of the filters mentioned above will work with the Mobil 1 oil or does anyone know the number for the Mobil 1 oil filter that will work with our common engine? Thanks ... Ken - Northern VA
CitadelBlue is offline   Reply With Quote
