At 25k miles on my '04, the rear or passenger side mount was replaced during a week long diagnostic session to find out why my van had a rough idle problem. The dealer ended up changing out the spark plugs and the rear motor mount. The idle issue when seems to have on away, it has been a few thousand miles since the repair.
I am not totally convinced that the spark plug cured the idle problem, I don't think the new motor mount is suppressing the rough idle either. Since the half of the intake manifold needs to be removed to replace the rear plugs, my guess is that I had a small vacuum leak that was fixed when new intake gaskets were fitted during intake installation.
I did not hear a creak before the motor mount was replaced.
