Hi guys, we seem to be having an issue at the moment with our battery. Not enough ooomph to turn the motor over in the morning. It did start first time when jumped so the battery was a bit low. This is the second time this has happened and both times were fine once jump started.
For a while now we have had a noise coming from what i think is something to do with the belts, it stops when the revs are up. Now i'm thinking that the alternator belt is slightly slack and needs tightening as it is the squeal from the alternator belt we can hear slipping. I checked the Volts over the terminals with engine running and at about 1500RPM's and it was about 13.8 volts. Is this correct? I have read somewhere it should be over 14 Volts.
Can someone tell me how to tighten the alternator belt to see if this is the problem before we go out and buy a new battery.
Thanks in advance for any help.
