I purchased a new remote for my sedonda. I cant find a programming form or procedure to program the second remote. Any Ideas??
Thank you and i will try it...Campduck said:Here is what you do.
1. Use a jumper wire, connect the jumper between terminal 12 and terminal 16 of the diagnostic connector.
( It should look like this)
2. Turn the ignition switch to the on position
3. Press the lock button two times.
4. If you have a second remote press the lock button two times.
5. Turn the ignition switch off and pull the key out.
6. Disconnect the jumper wire from the diagnostic connector.
7. Test each remote for function.
Might work for you, give it a try.
