The kia std fit roof mounts are fitted in front of centre row, drop out the plastic clip you can see in roof lining, theres a roof brace there, need to set up a mount plate screwed or riveted to that, then screw unit to plate cutting linig as required.
Power, take out the n/s centre grab handle (2 screws behind handle) also remove the nsf grab handle (2 screws) unclip the a pillar trim, you can then route power from the audio behind glovebox, up a pillar through roof linig to Screens. You would need to do this to get the signal up there anyway. theres a loom running down a pillar and behind glovebox to cable tie all your news bits to.
