Old 08-20-2005, 01:56 AM   #1 (permalink)
Donbf
Having been motoring for about 30 years I can remember the car engines of the late 60s and 70s requiring major surgery, possibly a new short motor at 100,000 miles or 160,000 kilometres. And what has technological advances done since those days with motors that now, quite happily rev. on through 300,000, even up to 500,000 kilometres with little or no fundamental repairs.
Image my shock and aggravation then, when our Kia Carnival engine, with probably less than 100,000 kms under its belt, proceeds to spit coolant into the crankcase big time. 'I've never seen anything like this", was the implausible and highly sus. exclamation of the local Kia dealer and, "Oh, YOU must have overheated it." He put us on the right path straight away; our fault, silly us.
Nice try mate. But I knew that the engine had not overheated because my early motoring experience is still with me: I religiously check the engine fundamentals of coolant, engine oil and of course, the safety items. So I kept asking myself and then others, why a basic item such as a seal below a cylinder would cease sealing at such low kilometres.
The more I inquired the more I learned about the Kia Carnival's known engine problems between 1999 and 2003. I heard about the head gasket trouble and the cylinder sleeves that loosen and then vibrate thus breaking the seal between the coolant's passage and that of the engine oil.
So I it put it to Kia Motors Australia that, as this is a 'known problem' happening on a low kilometre engine of theirs - this is the second motor in the 1999 Carnival - the owner's (that's me) reasonable expectations that he is motoring with a reliable engine has been heavily thwarted and therefore, Kia should foot the advised $6,500 bill.
I believe it is fair and equitable to expect a fundamentally reliable life out of an engine if the owner does his bit by monitoring the engine's vitals. Unfortunately, Kia has not done their bit and, judging by information coming to me, they seem to be intent on ducking their responsibility.
I have received a reply from Kia that they do not intend to fix the problem at their cost so I am now in dispute with them and I certainly won't be allowing them to use the 'out of warranty' excuse. KNOWN PROBLEM DURING WARRANTY; VALID PROBLEM NOW.
Signed,
Not Impressed
Donbf is offline   Reply With Quote
Old 08-20-2005, 08:52 AM   #2 (permalink)
seacam
Hello Donbf
You are right there have been stories of heads warping on the Carnival/Sedona models.
You don't say how old your vehicle is.
I am based in the UK as far as I'm aware you can no longer buy new petrol versions over here.
However I have come across two examples, one 1999, 2.5, 48,000miles on the clock the other 2001 2.5 with 78,000 miles on the clock, both blocks cracked at that milage.
Both engines were replaced under waranty but the 78,000 miler, the owner had to put up a **** of a fight with Kia UK, they claimed vehicle had been allowed to overheat, bla,bla,bla.
All power to you Don, take Kia on, I just don't think you're going to get anywhere
unless you can show there was a fault with your engine when built that's led to the problems your having now.
Mean while take a look at www.mycarstats.com, you will have to register.
Under the Kia Sedona,Carnival section don't be fooled by nothing showing under engine problems look through some of the posts.
The first one I came across was coolant leaking into engine.
Keep us informed
Seacam
Old 08-24-2005, 07:14 AM   #3 (permalink)
Donbf
Thanks Seacam, the Carnival is a 1999 model however it is a second engine.
I'll check out your suggested website.
Will keep the info. flowing.
Cheers.
Old 08-28-2005, 03:27 PM   #4 (permalink)
b1_n
Donbf,
Out of curiosity, was your 1st replacement engine a reconditioned one or a newy? I only ask as I had to have mine replaced c/- the cylinder sleeves failing. The old unit was swapped out for a new short motor, whereas previously they were replaced with reconditioned ones.
Have you had any other probs with your kia other than this?
b1_n is offline   Reply With Quote
Old 08-28-2005, 11:54 PM   #5 (permalink)
Donbf
I understand that first engine was a gasket problem and was replaced; hence 'A" after engine number. This is previous to my purchase so am vague on details. That episode however, did spit engine oil into the coolant resulting in an -unbeknown to me- uncleaned radiator going belly up on me being full of white gunk. $750 to replace that.
The only other problem with this vehicle that I encountered was the auto transmission kicking down into second during level even running and staying there for quite some time.
All of these failings are a great shame for a vehicle that is roomy, comfortable and smooth riding for a large family with luggage.
Cheers.
Old 08-31-2005, 10:44 AM   #6 (permalink)
jamescibie
jamescibie's Avatar
my kia carnival also spit coolant but not the way yours did. the bottom radiator hose had been rubbing against the chassis for the past 4 years (since i got it new), it eventually gave way (due to the constant rubbing) and made me lose all my coolant and overheat (good thing i noticed something odd about the level of the water thermostat monitor and pulled over). little glitches like this make me want to hate those kia engineers but, no, i still love my carnival and try to make her a better ride
jamescibie is offline   Reply With Quote
Old 09-03-2005, 10:59 PM   #7 (permalink)
Donbf
Jaimie, I would describe your problem under the heading of shoddy workmanship perhaps Mondayitis mistakes however my problem comes under the far more outragious endemic design faults the responsibility for which KIA Motors and dealers are apparently attempting to avoid once outside the warranty period, by accusing unsuspecting owners of overheating their motors.
Well, I am not accepting that nonsense from them; it is their inherent design fault and they will carry the cost of fixing the problem with a 6 month warranty as well.
Cheers
Old 09-04-2005, 11:38 AM   #8 (permalink)
seacam
Hello Donbf
Go for it,
Between 99/2001 there was a problem with a batch of the petrol engines, I think
Carnival engines are 3.5cc where as our version were 2.5cc
I have only been a Sedona diesel owner for about two months but when I first looked at the vehicle almost immiedatly I came across 2 petrol examples
where the heads or blocks had cracked and in the last few days two more owners now selling who also had to have the petrol version engines replaced.
As I write there is a forum member, Paul Woodhall, he is going through a simular
experiance as youself, he has had two heads in the last 18 months I think.
Some of the early diesel models had problems as well.
At the moment Paul is trying to nail Kia UKs a** to the wall.
Seacam
Old 09-26-2005, 07:52 AM   #9 (permalink)
kia going down
I am going through the same thing and I tell you i wont give up until i win, NEWSPAPERS AND TELEVISION HERE I COME....
I purchased a 2001 kia carnival only 4 months ago, with 110,000 ks on the clock., my car now has a blown head gasket. ( just like the other thousands) I got it towed to a Kia centre, they confirmed what the other mechanic said, a blown head gasket, needs a new motor, total $4751.05 , they put a claim in for me I got back a reply of NO we are not helping at all because it has already had a new short engine only 9000 km ago (which i did not know about) they 100 percent guaranteed me that the 2nd motors HAVE NEVER FAILED.
they also said it was my fault I must of overheated it, a Kia case manager said to me, "you were the only one on the highway, they are YOUR version of events, we dont know we were not there, so you must of overheated it." I authorised the mechanic to pull the motor apart and do what he had to, he found that the liner measurements were low. which is the reason the Carnivals motor has blown from day 1, the liners move and blow the gasket. The mechanics put a new claim in for me once getting these readings and were sure Kia would help, once again a no. So now I have all my information, from the internet, and I am lucky the mechanics are on my side, they say "i am sick of these companies getting away with murder". If Kia had of come back and said we will pay for parts and you pay for labour i probably would have said yes just to get my car back, well now they have blown it, I will be going for eveything, motor, labour, hire car, loss of work, stress, I have printed out all the letters from people it has happened to and ruined lives, I am getting an engineer to do a report on the motor tomorrow, I have lodged a complaint with department of fair trading, if they cant do anything I am Taking Kia to the CTTT, $30 to lodge the claim for a judge to hear. I have come on here and in 2 hours found all these letters that are the same, some families have paid up to $14000, cmon people do something about it, why should they get away with this. I will not stop until they pay for my motor, I dont care how far i have to go, if that means today tonight Ill be there. But the more people who put in complaints the better it will be for all of us.
and about people getting a new short engine, YEAH RIGHT
my new short engine thats only 9000 km new, well it was a refurbished one,
Kia lied to me on the phone and said no no it is new, but it isnt, they forget engines have numbers and history.
I also got told today the engineer must come tomorrow, as the broken engine needs to be sent back, I asked where, oh its an exchange, they get this motor, what so some poor family gets it again for the third time. ITS ROBBERY.
my dream beleive it or not was to own a KIA one day, what a dream this has turned out to be, I dont have that sort of money to pay repairs, whats the saying
becareful what you wish for..................UNDERSTATEMENT
kia going down is offline   Reply With Quote
Old 09-26-2005, 11:15 PM   #10 (permalink)
Mark_1971
We have a 2001 carnival that we use for our Childcare centre for school runs. It hasnt hit 60,000km yet and has just joined the legion of lemons. Without any warning, the radiator filled up with engine oil. Its less than a year out of warranty. The dealer said they will need a week before they can look at it, because they have overbooked their workshop by 20 hours every day??? Funny part when i was there with the tilt tray, there were about 4 guys standing around chatting, occasionally looking into engine bays, basically doing nothing. I'm told that "if it needs a replacement engine" that will take 8 weeks !!! Gee, I wonder why there is such a delay?? Must be a high demand on these motors?
Sounds to me like we're going to get the same BS response. Kia knew there was a problem long ago. Given the extrodinary rate of failure of these motors, I would have thought that a recall should have issued. I think they have deliberately let it go, wearing those that failed under warranty, and brushing off any that failed outside of the warranty period as "not there problem"
With so many people in the same boat, maybe we would be better to take them on as one large group, instead of individually. Class action comes to mind.
Good luck with it all anyway.
Mark_1971 is offline   Reply With Quote
