Sedona 2.9 Auto on an 02 plate.
Hello,
I have received my ProfiTune Box off the Ebay site and will fit it next week.
I have some questions.
The postings from Clarksonly and Dubana have made the fitting of it relatively easy thank goodness as the instructions received with my box were poor.
If I'm not mistaken both of them have 03 Sedona's, mine is an 02, is it safe to assume they have the same engine as fitted in mine?
If so I noticed the picture that Dubana posted of his box had the number Pt20050260 on the front where as mine is Pt 20050360, I was wondering why the difference?, perhaps Clartsonly you can look at your receipt and post the number.
Clartsonly, you said in your post, "the Kia adapter has a different guide line position on its connector the easiest thing to do is to remove this line from the bottom it took a couple of seconds with a Stanley knife." ( a little unhappy about altering one of the cars original parts )
Bearing that in mind, if you have to put everything back as was, will the original connections be a little loose, would it matter, what do you think?
After fitting the box Clarksonly showed a picture stating no engine light, I'm a little confused, what lights won't work and are they/it important?
The supplied cable is the FCI type, the D connector is two part, the female side is connected to the supplied cable and I presume this fits on to the box but what do I do with the male side if anything? it's not fitted to the cable.
Any opinion on settings?
Seacam
