Hi,
I'm not sure if this will help you or not (but thought it worth a share anyway).
I recently installed a 'magic mirror' in/onto my 2005 Sedona and whilst routing cabling, namely behind the plastic panel that runs from the roof panel towards the dash facia (sited on the left of the front windscreen) moved some cabling that interferred with the connection/sound to the cd/radio player. After some fiddling, I established a loose wire connection which I put right and 'touch wood' appear to have solved the cd/radio cut out.
I'm no expert and I'm not saying that this will solve your problem but it may be worth a look.
I did have to carefully remove the cd/radio player and facia also to make this problem good.
Fiona
smiles across the miles
