Hello, Just bought a used Kia Sedona 2003 EX. The cruise control does not work. When I push the cruise control button near the radio, the Fog Lights come on instead. When i push the Fog Light button, nothing happens. The green Auto cruise light on the dash never comes on. I know the green auto cruise light is there, because I own another Sedona. It does appear the center console was messed with, since one of the heater knobs is upside down. Thanks
Hi. Sorry about your issue.
It appears someone has messed with the electrical controls before. You may need to remove the center console cover, and rearrange the connectors to the proper push-switches. To remove the console cover, remove the ashtray and the screw behind it, then pull (by hand) the trim out, starting form the bottom then upwards; be careful, don't break it.
Also, you may need to remove the instrument cluster set to check the bulbs behind the indicator lights (use page 4-21 in the owners manual as guidance). Use a stubby phillips screw driver; disconnect the battery before to prevent any accidental short.
Please post your results, with either positive or negative results.
Good luck there.
MV
