Old 06-08-2009, 05:50 PM   #1 (permalink)
galaxy tdi
Default sedona immobiliser
im having problems starting my 2.9 tdi the immobiliser light comes on then goes off but a friends sedona the immobiliser light stays on till car has started which is correct any help appreciated
galaxy tdi is offline   Reply With Quote
Old 06-13-2009, 06:42 AM   #2 (permalink)
John Kelly
John Kelly's Avatar
Drives: Kia Sedona SE 2.9CRDi Auto
Hi
Checked mine yesterday. IMMO light stays on after all warning lights have settled down. But if ignition left on it goes out after 30 seconds but it still starts ok. Hope this helps.
Regards John.
John Kelly is offline   Reply With Quote
Old 07-02-2009, 11:36 AM   #3 (permalink)
kevmacleod
Drives: kia sedona 2.9 lx
Mine stayed on, then went off and started, it then started being a hit or miss whether the car would start, there is wire that goes around the ignition switch, i removed the cover and disconnected the connector and reconnected it and put it all back toghether, car has not failed to start since?? coul dhave been the connection was lose, worth a try??
kevmacleod is offline   Reply With Quote
Old 07-10-2009, 09:10 AM   #4 (permalink)
westj66
The same thing happened to my 03 2.9, it turned out to be the receiver ring that fits round the key hole of the ignition switch.
Basically you have a signal sent by the chip in the key that is picked up by the receiver/aerial ring and in turn cancels the immobilizer. Now the important bit. The replacement costs about £25 and you need to carefully remove the steering column plastic covering and trace the wire back to its connector and unclip. The ring is fixed in place by a small screw, remove this and slide the ring off. Replacement is a reverse of this.
Hope this helps, mine now starts faultlessly.
westj66 is offline   Reply With Quote
