Alaska trip
Well it's been awhile but I was in Fairbanks for a couple years. Untill September it's like Colorado, after that- hoses and belts need to be rubber, not synthetic (they may shatter at -35-50 deg. F) an interior warmer heater (leather/vinyl will split,dash cracks,older sterring wheels cracked) mounts under dash, battery hot plate or blanket ( or you have to bring battery in the house) I had a V8-used a "purculator" type heater to circulate heated water thru engine which in turn heats oil, also had a 4 cyl-used a "can" heater in lower radiator. your vehicle will NOT start if not plugged in. I put a 4x4 outlet in the engine compartment, routed cords to it, ran the cord to the grille, fastened with wire there, carried an extention cord to connect from car plug to where I was plugging in, also use some kind of indicator light (110 volt) that you can see from indoors so you can tell you are getting power to car, some people used a small xmas tree lt. set. also the whwwl bearing grease should be a lighter weight, I saw more than one car going by with one wheel "stationary", once you get some friction going on wheels turn ok. once you get set up its not a hassle, vehicles are a priority in the winter, I should mention anchorage does not get as cold as fairbanks, I saw a minus 72 deg. one time, usually -10 to -35, keep in mind-very dry cold, little wind, the colder it gets-the stiller it is, much better than N.D. at -10 with a 30 mph wind (chill factor) if you wait till you get there the process will be easier, but more expensive. It is truly beautiful-pristeen, you won't forget it. maybe the "ALCAN" highway is paved now, then you could count on a cracked windshield from rocks, and you had to have certain things "onboard" or they would not let you enter. Regards from a sourdough to a chichaco
