Old 09-27-2008, 03:14 PM   #1 (permalink)
collins2179
Unhappy Sedona 2.9 '04 won't start.
Hi Ive got a 04 sedona 2.9 diesel adout a week ago it started to start a bit sluggish [normaly first crack] I thought i had a fuel problem I changed the filter and put fortie cleaner in no better I have drain the diesel and put new in .The starting is worst i can get it going and it runs fine until i stop then its hard work starting again having to resort to easy start .Now the engine control malfunction light is on any ideas thanks Paul
collins2179 is offline   Reply With Quote
Old 10-26-2008, 09:45 AM   #2 (permalink)
mk1rs
it needs to be put on the diagnostic machine m8
mk1rs is offline   Reply With Quote
Old 10-26-2008, 01:55 PM   #3 (permalink)
ch pied
carefull with the easy start , has been knowen to crack a head , with over use , as mk1 say's , need's plugged in
ch pied is offline   Reply With Quote
Old 10-31-2008, 09:16 AM   #4 (permalink)
gareth
i had the same problem on my 05 van and check for under voltage on the battery and checked the relays,first it would start then not even when warm.so i changed the starter motor with a s/h one [check the parts find sites big dif in price £45 to £120].
you have to do the job from under the van and it takes about 2 hours with removing the air intake air filter box to get at the top nut.
if you need to know how to do the job to will only to please to email the way i went about it [email gareth.walker@blueyonder.co.uk] the problem could be the motor bushers sticking and with colder temps not moving in there casings.
gareth is offline   Reply With Quote
Old 01-08-2009, 01:22 PM   #5 (permalink)
kris_lpgcars
Drives: audi a4
does it cranks ok???? if yes just check what you've got in the tank removing top cover under the seat simple job , i had many times to find a loot of rubbish in the tank which is more likley to thru the filter a end up in the injectors. before removing injector you can check the IMV simply removing from back of the pump and visually check it . its more likley so the valve start sticking and start to bring fault codes P0119, P1120, P0190 which indicates fuel press under tolerance in this case you can start from cleaning IMV ( blow air thru the hole on it)
kris_lpgcars is offline   Reply With Quote
Old 01-16-2009, 03:59 AM   #6 (permalink)
kia-kaput
sorry for sounding thick but whats the IMV?
got similar prob, thought fuel pump, how can fuel pump/fuel pressure be tested without removing it?
kia-kaput is offline   Reply With Quote
