I'm quite new to this forum, having only owned my 2001 Carnival 2.9 Tdi a few weeks. Overall I'm impressed with the vehicle but until Thursday I hadn't exactly driven very far.
On Thursday evening my temperature gauge suddenly wound itself off the scale, I'd driven about 100 km but as luck would have it I was on the return journey and about 5km from home.
Friday morning I poured in
5 LITRES of water, drove the car .......... no problem, then in the afternoon same problem ..................
"WAIT A MINUTE" where's all the chuffin' water going I can't see any obvious leak.
After some investigation, following all the pipes I arrive at the rear of the vehicle.
That rear heating system is a great innovation but the two rubber pipes that come out of it join two steel pipes attached to the chassis ............. these two pipes were looking suspiciously corroded
................ low and behold I'm losing water ......... not at an astronomic rate but enough to lose me 5 litres of water every 100km.
Pulling on the old coveralls to look deeper into the problem I took hold of said metal tubing and it broke off in my hand, a faceful of diluted glycol that's been in the heating system a while doesn't taste very nice I can tell you.
Removing the spare wheel, then using a hacksaw I'll shorten the metal tubing. Then with a few new lengths of 16mm water hose (bent to 90 degrees), two lengths of metal tubing (16mm) to rejoin the hoses, I will cure this problem.
Just thought I'd share this experience on the forum because it's bound to happen to someone else sooner or later.
Cheers
