Old 05-23-2008, 06:01 PM   #1 (permalink)
PeteB_2000
Default Strange engine Idiling problem
Hello again
After my timing belt change the engine is now idiling at around 1000 revs...strange thing is if my depress the foot brake it drops to a more "normal" 750revs foot off the pedal and it goes back up
Any ideas what may be causing this ??? is it coincidence ??
All help graciously received
Pete
Old 05-23-2008, 09:37 PM   #2 (permalink)
Steve1234
You should probably change your timing belt again.
Hahaha - but seriously, are you talking about when in drive? Or parked in neutral?
Steve1234 is offline   Reply With Quote
Old 05-24-2008, 02:46 AM   #3 (permalink)
ron1004
Drives: Kia Elan
My guess is that you have an intake manifold vacuum leak - check all the vacuum hoses and listen for the suction hissing while idling.
Old 05-24-2008, 09:23 AM   #4 (permalink)
PeteB_2000
just sat in neutral with the engine running up it shoots to around 1000 press the brake and it comes down to what IMO it should idle at around 750
Old 05-26-2008, 06:23 AM   #5 (permalink)
PeteB_2000
not noticed any hissing noises guys anymore ideas?
Old 05-26-2008, 07:53 AM   #6 (permalink)
sedona no 1
Drives: 2000 Sedona SX ; 1997 Rover 214Si 16v
It does sound like a vacuum leak from somewhere as when you press the brake, it is also using the vacuum but if too much air is getting to the air intake without pressing the brake then the revs will shoot up. Could be a split in a pipe somewhere. Check the vacuum pipes coming from the alternator, air intake and the air tank on the bulk head.
sedona no 1 is offline   Reply With Quote
Old 05-30-2008, 06:41 AM   #7 (permalink)
PeteB_2000
ok SN1 will have a mooch around the engine bay
Old 05-31-2008, 08:18 PM   #8 (permalink)
TEXKIATECH
just gat like two cans of carb cleaner and spray your engine all over till you hear it die down then you have found your vaccum leak. i would check the brake booster line first
Old 06-01-2008, 03:31 AM   #9 (permalink)
ron1004
Drives: Kia Elan
Inspect the non-return valve in the vacuum line going to the brake booster.
Old 06-02-2008, 08:56 AM   #10 (permalink)
93fxdl
93fxdl's Avatar
things seem a bit confusing here on a petrol engine the brake servo is fed by vacuum from the inlet manifold but pete yors is a diesel so there is no manifold vacuum to feed the brakes it is supplied by a separate pump which i believe (could be wrong mind you)
is attached to the alternator or it could be a separate pump sorry but i cant be any other help but it sounds as if putting the brake on is putting extra load on the engine either electrical or the vacuum pump a couple of tests to see where the load comes from 1 disconnect the brake light switch and try again if no improvement fault is in the vacuum system 2 disconnect vacuum pipe from pump and test again
another possibility is something haywire in the engine management but what do i know
ttfn glenn
