Old 06-03-2008, 07:41 AM   #11 (permalink)
PeteB_2000
hiya guys thnx once again for your input,
Im at a loss to know what or where the brake booster or vacuum pipe are, and if Im reading your emails correctly your saying theres a prob in the brake system somewhere
I may be misunderstanding your advice or I havent put myself across correctly but prior to doing the timing belt change with the engine running in neutral gear the revs would be around 750, since my DIY job the same situation is now around 1000 noticeably higher that even the Mrs noticed it, strangley it returns to around 750k when pressing the footbrake, so its not the case of the footbrake putting extra load on the system but the fact its sat at 1000k revs when doing nothing
Hope that makes a bit more sense
Pete
Old 06-03-2008, 08:16 AM   #12 (permalink)
ron1004
Drives: Kia Elan
Pete
It seems like something was disturbed when the TB was done, and this is causing air to be drawn into the inlet manifold, and this air which effectively bypasses the throttle causes the higher than normal idle speed.
It sounds like there may be a vacuum leak in the brake booster, which seals when the brake is applied - as a test take off the vacuum pipe going to the brake booster and close it with your thumb and see what the idle speed does - it should idle around 750.
Old 06-03-2008, 08:19 AM   #13 (permalink)
93fxdl
93fxdl's Avatar
the brake booster aka servo is the large round thingy which the brake fluid resevoir is attached to
ttfn glenn
Old 06-03-2008, 08:23 AM   #14 (permalink)
ron1004
Drives: Kia Elan
Important to note that as " ttfn glenn" points out my advice is based on a petrol engine, as the vacuum source on the diesel is different.
Old 06-03-2008, 04:00 PM   #15 (permalink)
PeteB_2000
Could it be something to do with this thing called the "Fast idler kit" ?
Old 06-04-2008, 12:51 PM   #16 (permalink)
sedona no 1
Drives: 2000 Sedona SX ; 1997 Rover 214Si 16v
Look at your alternator. On the back you will see lots of pipes coming out the back going to different places. One pipe should go to a black canister attached to the firewall, then a pipe from that goes to the brake servo.
Check all of these pipes out. One of the pipes coming from the back of the alternator goes to the fast idler.
sedona no 1 is offline   Reply With Quote
Old 06-05-2008, 04:41 AM   #17 (permalink)
PeteB_2000
ok thanks guys I think I know what you mean now, I take it I can just pull these hoses off with the engine running?, also are they no fluids running through them?
cheers
Pete
Old 06-05-2008, 02:01 PM   #18 (permalink)
sedona no 1
If you do the ones i've said then there is only air/vacuum going through them.
