hi again , here is a link to the instalation diagram could not seem to add ot to this message ???
http://img.auctiva.com/imgdata/5/0/1...30864733_o.jpg
dont worry about which way to turn just gently turn untill the timing marks line up if there is any contact you wont be able to turn and there will be no damage if done gently .
my advice : first breath take a breake and clear your head , next the twin cams wont stay in place cut a piece of steel and put between the teeth toward the bottom .then put one of the engine mounts bolts in the screw hole between the cams, line the markins up and wedge somthing to hold them in place between the bolt and the steel piece , next the pump sprocket hole is bigger than the locking hole in the engine i used a pin the width of the sprocket hole and cut it down on the end to make a tight fit . and as for the bottom end there is a notch on the sprocket and one just above at about 12 oclock line these up ,
you wont get the bottom 38 mm bolt out with a ratchet the engin will just turn you need a impact gun a cheap impact gun in woolworths is £20 that should do the job or do llike i did and ask a mobile tyre fitter poped it of in seconds .
hope all this helps its bank holiday monday and im fighting my injectors to work should be away for the weekend but im having a break will it rains.........best wishes mark
