02 sedona problems running
Hi everyone.
I have an 02 sedona with 141,000km my problem is 1 day i got in it to go to work and it would not run,it idle's revs up and down until it stalls out, i tried 2 footing it to get to work but when i hit the gas i didn't want to move? i did have a check engine lite on it was p0102 mass air flow sensor low circut? the garage changed that out for a mere $300 dollars for the sensor, and it still didn't run then they told me it was my map sensor acting up, changed it with no results. Now they want to try a new MAF sensor and if that doesn't work they are telling me we will ahve to look at the computer. Now they are tell me all this because if you unplug the MAF sensor the van runs fine, has anyone ever had this problem before or no what i should be looking at?
Thanks in advance
Roger Crooks
