Power Sliding Door No longer works - Kia Forum
post #1 of 9 (permalink) Old 05-13-2012, 01:26 AM Thread Starter
Drives: 2007 Kia Sedona EX/2007 Chevy Trailblazer SS
Hello I have an 07 Sedona EX with rear power sliding doors. Recently the read drivers side door no longer functions.. It has to manually opened and closed. The rear passenger still works as it should.
When I press the button on the remote or the overhead console nothing it does not respond.. When I press the button to close it via the rear passenger door I sometime will get a beeping sound.
I have checked the fuses in the rear cargo and it looks good.. I even swapped the right and the left to make sure that the fuses are good, and the were.
Anybody have any ideas or is this a trip out to the dealer to fix? or is it something I can fix.
Thanks in advance.
etperez22 is offline
post #2 of 9 (permalink) Old 05-13-2012, 07:58 AM
Drives: 2007 Kia Magentis LX
There is a switch at the fuel filler door that prevents the left slider from opening if the filler door is open. The switch is somewhat exposed to outside elements and may not be functioning properly (happened to a 2006 Sedona owned by a friend). Might be worth your while to check that out first.
p_mori7 is offline
post #3 of 9 (permalink) Old 05-13-2012, 09:13 AM
Quoted: 10 Post(s)
There could be many things causing this problem. It would probably best to have the dealer diagnosis it before you start changing parts. At least they could tell you what is wrong, and then you can decide if you want them to fix it or try it yourself.
spongebob218 is offline
post #4 of 9 (permalink) Old 05-22-2012, 09:22 AM
We've had problem after problem with the power doors on our '06 Sedona. Now it's doing it again...The dealer has replaced modules, latches, switches and motors. We still have intermittent door problems.
At 93K, the factory won't cover it, though the problem has existed since about 2K. We bought the AutoGuard extended warranty (at dealer suggestion) and since 60K we have to pay a $100 ded. for each return visit. That coverage runs out at 100K.
bluesedona is offline
post #5 of 9 (permalink) Old 06-09-2012, 07:19 PM Thread Starter
Got it back from the shop.. It was the door actuator..
post #6 of 9 (permalink) Old 04-14-2013, 07:37 PM
I have a similar problem, on my 2007 Sedona EX that i have been diagnosing for the last 6 months. Everything works fine until i open and close the fuel door. Upon closing the fuel door i am able to only manually open and close the sliding door. When i attempt to automatically open/close the sliding door i get the 1 chime (beep). If i cycle the fuel door (open and close it) the automatic cycle will eventually start working fine again. The actuator seems to be working fine and i can manually unlatch without an issue.
So basically, i am trying to figure out where this fuel lid/door sensor or switch is that tells the door that the fuel door is open. If i can locate this switch i can troubleshoot it further. I searched for the schematic, exploded views on parts websites and at hyundai tech info dot com under entourage and it is very vague as to the location of it....I just can't figure out where this is located. Can anyone help me pinpoint where this is?
cmac518 is offline
post #7 of 9 (permalink) Old 08-16-2014, 04:17 PM
awi2035's Avatar
Drives: 2007 Kia Sedona Ex
Quoted: 5 Post(s)
I replaced the actuator motor in my 2007 Kia Sedona Ex and that did help, but I discovered another problem with another cable in the door motor assembly. Now I am looking for a parts list so I can order a new cable.
awi2035 is offline
post #8 of 9 (permalink) Old 08-16-2014, 08:11 PM
awi2035's Avatar
Quoted: 5 Post(s)
2007 Kia Sedona EX
Originally Posted by awi2035 View Post
I replaced the actuator motor in my 2007 Kia Sedona Ex and that did help, but I discovered another problem with another cable in the door motor assembly. Now I am looking for a parts list so I can order a new cable. I
I found the part number for the door Actuator Cable 81446-4D501, which fits both doors. The shipping on the item is twice the cost of the part.
awi2035 is offline
post #9 of 9 (permalink) Old 08-26-2014, 06:29 AM
awi2035's Avatar
Quoted: 5 Post(s)
I have a 2007 Kia Sedona EX also and would like to know too. I haven't been able to find a switch. There is one inside the fuel door but that is the auto latch for the fuel door to open when I push the button on the drivers side front door.
awi2035 is offline
