How to Change front turn signal bulb??? - Kia Forum
post #1 of 3 (permalink) Old 11-09-2010, 01:44 PM Thread Starter
Hello Everyone.
Anyone know how to change the front turn signal bulb on a 2007 KIA Sedona?
I've opened the hood and removed the bolt at the top of the headlight, but am unable to pull the headlight out away from the body of the van to gain access to the back of the headlight unit to change the bulb. Seems like something else (bolt/fastener) is still holding the headlight in place.
Thanks in advance!
winsys is offline
post #2 of 3 (permalink) Old 11-09-2010, 03:03 PM
Drives: 04 sedona,94 suburban,97 sephia Tuned & ported
remove all the little plastic clips holding the upper trim plate and remove the complete trim plate from vehicle, after that your will see there is another 10mm bolt holding the headlamp assembly in place, there actually is a hole to access this bolt through the trim plate but you still need to remove at least half of the clips to remove headlamp assembly.
FlatRate572 is offline
post #3 of 3 (permalink) Old 11-10-2010, 09:57 AM Thread Starter
You were spot on.
I removed the second 10mm bolt and half the plastic trim clips/screws from the upper trim plate and was able to 'work' the headlight free from the body of the van and then change the turn signal bulb.
Thanks FlatRate572.
winsys is offline
