Just because a machine says the wheels are balanced does not mean they are not deformed. I have a bad rim on a new Kia ..... have not got around to making dealer exchange. If I did not have access to shop equipment I might be in same boat you are. Here is a post from Spectra board. My Sedona and other Spectra do not have issues with balance.
"Just purchased a 2006 Spectra new, did not get over 60 on the test drive. On way home had a slight shimmy at 65-70. Put all the tires on a new dynamic balance machine that uses lasers to 3-D image rims and tires (at my father-in-laws auto shop). One rim was ok, two were somewhat out of spec. One was bad enough that although could balance, the machine said was the equivalent of 2.5 Oz out at 65-70 mph (owing to harmonics) no matter what. Machine can be seen at:
John Bean - Automotive Wheel Service Equipment
Operator of machine can print out spec sheet which documents problems with rims / wheels. Plan to hand to Kia service tech and get wheel put on new rim.
Moved bad one to rear until I get Kia to exchange it. My Kia Spec5 16" alloys were near perfect. Plan on using those come spring.
George in Wisconsin."
