Model Sedona
Gr./Sys./Comp : Fuel System / Engine Control System / Brake Switch
Symptom : EN1000 - Hard/No start
EN4000 - engine stalls
EL5000 - lighting system malfunction
ELN003 - Others
Subject : Safety Recall Campaign: 2006 Sedona EX Stop Lamp Switch Wiring Reposition (SC065)
Description :
This bulletin provides a repair and/or relocation procedure for the stop lamp switch wiring harness on 2006 Sedona EX vehicles equipped with adjustable pedals with production dates between June 15, 2005 and May 18, 2006. It is possible that 2006 model year Sedona EX vehicles equipped with adjustable pedals, an improperly positioned wiring harness can make contact with the U-joint assembly of the steering column. Repeated contact may eventually cause the wiring insulation to wear through leading to chaffed wires. Chaffed wires could cause a short of the wiring harness resulting in the loss of brake lights, engine stalling or an inability to start the vehicle.
Vehicles Affected : 2006 Sedona EX vehicles equipped with adjustable pedals with production dates between June 15, 2005 and May 18, 2006
