intermitent overheating - Page 2 - Kia Forum
 9Likes
post #11 of 16 (permalink) Old 02-15-2017, 01:05 PM
Drives: 1999 Kia Elan
Quoted: 380 Post(s)
Originally Posted by jdm74 View Post
In idle the problem does not exist, normal temp before/with fans on aprox 200, the hoses seem to be normal, and could not see anything leaking.
Although Ive noticed the bottom of the transmission has also been sprayed with coolant (more than the top, I would say)
The rear heater (at idle) is not blowing really warm air, to me its just normal (non ac caribbean air)
That points to the likelihood of a blown head gasket, under load it leaks combustion gas into the coolant passages.
Originally Posted by aquanaut20 View Post
Conduct a coolant combustion test, then replace the thermostat if clear..
... Philip
jdm74 likes this.
ron1004 is offline
post #12 of 16 (permalink) Old 02-15-2017, 04:14 PM
Drives: 2008 Grand Carnival
Quoted: 3 Post(s)
Any chance of getting a pressure tester and checking your cooling system holds pressure? If it holds pressure for a period of time, there are no leaks in the cooling system.
jdm74 likes this.
anjcol is offline
post #13 of 16 (permalink) Old 02-15-2017, 06:25 PM
aquanaut20's Avatar
Quoted: 165 Post(s)
May not be good enough for this issue, does not error at low RPM/pressure, (pressure tester only applies ~15psi) best with a gas tester..
... Philip
jdm74 likes this.
aquanaut20 is offline
post #14 of 16 (permalink) Old 02-15-2017, 06:28 PM Thread Starter
Drives: 2014 Kia Sedona
BTW Sunday I drove aprox 150 miles back and forth, thru mountains, the temp was normal all the way there and back, Saturday last, its the first time I noticed the overheating, it was aprox 100 miles r/t, but on the way back, temp was normal the whole way.
Commute in the morning is about 15 miles, just a ver moderate hill about 1/4 mile, the rest downhill or flat, although stop and go traffic
Pressure test and combustion check next.
jdm74 is offline
post #15 of 16 (permalink) Old 02-15-2017, 07:01 PM
Drives: 09 kia spectra ex
Quoted: 110 Post(s)
Need to find the LEAK that sent coolant out all over the transmission. AND my guess is huge air pocket trapped in lines to rear heat unit.
jdm74 likes this.
MIA KIA 09 is offline
post #16 of 16 (permalink) Old 02-16-2017, 11:22 AM Thread Starter
Will bleed from heater lines tomorrow and lets see what happens.
Today, lets mess with Pick Up day or walk..
jdm74 is offline
