Strut/shock rear mount broken - safe to drive? - Kia Forum
post #1 of 5 (permalink) Old 03-13-2012, 10:59 AM Thread Starter
Drives: Kia Sedona 2.9LX 2003
Trying to get hold of the parts at the moment, and get my mechanic to fix but I've got to drive 200 miles to customer and not sure if I can get it fixed beforehand.
Looking at rear shock, it looks like the top bit including a rubber bit is lose and the shock is rattling around. When driving, it gets really rattly.
I guess whats happening is when I hit a bump I'm not getting the dampening I should get.
It seems to be handling OK at the moment but I dont want to drive if its unsafe....
psychocandy is offline
post #2 of 5 (permalink) Old 03-14-2012, 04:04 PM
Drives: '02 Sedona 3.5L
Hi psychocady,
Looking at the pic, it doesn't seem anything broken. All it is the shock retaining screw came off or if worse, the shock is dead.
No one is going to tell you it is safe to drive the van for 200 miles with a bad shock, but I can tell you the shock is not going to completely come off if you drive carefully.
Regardless, you need to replace this shock. I would replace both side. If you need it in a hurry, go to local part store and get it; if not order it from Amazon: KYB 344296 GR-2 or Monroe 911272 Reflex.
If you want to DIY, all you need is removing the 4 big bolts holding the shock mounting plate while you don't even need to jack up the car or remove the wheel. The bolts might be hard to break, you can sit down on the floor and push with your leg on the breaker bar or wrench. If you have changed shock before, it probably takes 20 min.
Good luck and post back.
Hope this helps,
Bruce
bruce2 is offline
post #3 of 5 (permalink) Old 03-15-2012, 04:24 AM Thread Starter
Originally Posted by bruce2 View Post
Hi psychocady,
Hope this helps,
Bruce
Hi Bruce,
Yeh. You might be right. Think the top bolts are still there but really loose somehow....
post #4 of 5 (permalink) Old 03-15-2012, 09:52 AM
Drives: 2005 Sedona EX
For what it's worth, a co-worker of mine had a retaining nut come off the top of the rear strut of his VW Jetta, but continued to drive only to hit a big enough bump to allow the strut to pop out of the mount piercing the rear tire.
EVH5150 is offline
post #5 of 5 (permalink) Old 04-07-2012, 09:12 PM
So long as the shock is retained, only the top mount rubber has perished away.
Then all should be okay short-term till ya fix it..
KV6 petrol engine variant.
Conglomerate is offline
