2005 Steering hard sometimes-- - Kia Forum
post #1 of 4 (permalink) Old 12-11-2011, 07:21 PM Thread Starter
My 2005 turns really hard at low speeds, sometimes.
Started after hearing a belt squeal in the morning. It was bad, almost impossible for my wife to turn to park.
Trying to test if the belt was loose I sprayed it with some belt conditioning spray. Did not seem to help.
I also lubed, with some spray lube, the steering intermediate shaft.
Nothing helped.
Today it was a little better, but still had trouble in a parking lot one time. I parked it several times today.
Later I put a couple turns on the tensioner for the power steering pump. Drove it for a little while and it would catch at the start of a turn. Then it would turn normal.
Loose belt? Intermediate steering shaft? Steering pump? Always steers easier if I give it a little gas.
I am not sure what to try so I can narrow down what the problem might be.
STeve
Electech1 is offline
post #2 of 4 (permalink) Old 12-12-2011, 12:21 PM
Pacosworld's Avatar
Quoted: 12 Post(s)
Nothing helped.
STeve
The intermediate steering shafts have a history of the u-joints loosing lubrication and causing the problem you're describing. You might start with replacing that and go from there.
Mike AKA Paco
Pacosworld is offline
post #3 of 4 (permalink) Old 12-12-2011, 02:51 PM
Drives: kia sedona 2.9 tdi 2002
hi
i may be stating the obvious but have you checked the fluid level?
regards kia mad uk
KIA mad is offline
post #4 of 4 (permalink) Old 12-19-2011, 03:11 PM Thread Starter
The fluid level is fine.
I bought some spray lube and sprayed the steering shaft. For another day I had problems. But now it is gone. It has been a week.
I will order a replacement shaft.
