Sedona Front Interior Door Handle Replacement - Kia Forum
post #1 of 7 (permalink) Old 06-09-2006, 03:42 PM Thread Starter
Inky's Avatar
SPECIFICATIONS: This is specific to the 2002 Kia Sedona but likely applies to other years and models as well.
NOTE: The interior handles for the front doors have a stop tab on the metal back plate. Over time, the metal wears away the plastic on the handle until the handle is able to clear the stop, allowing the handle to be pulled too far where it may break. If your handles are over a couple of years old, examine them. Bend the stop up as specified even if the plastic hasn’t significantly worn. (This also applies to your replacement handle, new or used.)
PARTS NEEDED: Replacement Interior Door Handle Specific to Door (left or right)
TOOLS NEEDED: Small Regular Screwdriver or Pocket Knife; Phillips Screwdriver; Support to Rest Door Panel on (if desired); Pliers (to adjust stop on metal back plate)
TIME: Only 15 to 20 minutes
PROCESS:
1. With door open, use small regular screwdriver or pocket knife to remove cap covering screw in center of trim piece behind handle.
2. Remove single screw and trim piece from behind handle.
3. Remove single screw from plastic "pocket" atop armrest on door.
4. Remove both screws from lower part of door panel (at corners).
5. Working bottom up, pull door panel away allowing fasteners to pop loose from metal door. Lift lip from edge near window.
6. Support door panel or separate wiring harnesses and set panel aside.
7. Remove three screws securing old handle to door.
8. Remove lock rod from old handle (swing plastic clip back and pull rod up).
9. Remove latch cable from old handle (swing plastic clip back, pull cable end up, and remove plastic cable guide).
BE SURE TO MODIFY STOP ON METAL BACKPLATE OF HANDLE AS MENTIONED ABOVE.
10. Attach lock rod and cable to new handle (reverse of 8 & 9).
11. Secure new handle to door (reverse of 7).
DO NOT OVERTIGHTEN SCREWS. SNUG AND THEN TIGHTEN ONLY A SLIGHT BIT MORE.
12. Reattach to door plastic sheet acting as dust barrier, if necessary and so desired.
13. Ensure securing clips are attached to door panel (and didn't stick in door).
14. (Reattach wiring harness(es) if separated in Step 6.) Reattach door panel (reverse of 5).
HINT: If the screw from the "plastic" pocket is rusty or dirty, use it when reattaching the door panel and use one of the clean panel screws in the "pocket."
15. Reinstall screws into door panel (reverse of 4). DO NOT OVERTIGHTEN.
16. Reinstall screw into center of plastic "pocket" (reverse of 3). DO NOT OVERTIGHTEN.
17. Reinstall screw into center of trim piece behind handle (reverse of 2) and trim cap (reverse of 1). DO NOT OVERTIGHTEN.
-- Christian
Inky is offline
post #2 of 7 (permalink) Old 06-11-2006, 03:28 AM
Well written procedure Inky,
sure it will help many.
cpapashley is offline
post #3 of 7 (permalink) Old 06-19-2006, 02:26 PM Thread Starter
Inky's Avatar
Thanks!!!!
-- Christian
Inky is offline
post #4 of 7 (permalink) Old 12-29-2006, 10:35 AM
Would this procedure be similar for the back sliding door?
New here, this has lots of great info.
Would the procedure in principle be the same for replacing the handle on one of the sliding doors?
goonbutt is offline
post #5 of 7 (permalink) Old 12-29-2006, 11:37 AM Thread Starter
Inky's Avatar
I've never replaced a handle on one of the sliding doors but I imagine that the basics would be similar.
-- Christian
Inky is offline
post #6 of 7 (permalink) Old 05-22-2010, 11:50 AM
I just replaced the handle as you described - thanks. I would just add one step:
(between steps 2 & 3): Remove the triangular piece of plastic trim which is on the interior side of the side mirror. This is done by prying it away from the door with a flat-head screwdriver.
Here's a link which details the process in words and pictures: Remove A Car Door Panel On A 2005 Kia Sedona
Adding this step will fully expose the windowsill which the top of the door panel hangs from. Otherwise, it will be really tough to get the door panel back on.
guavaguy is offline
post #7 of 7 (permalink) Old 04-02-2017, 04:11 PM
Drives: Sephia 2001, Sedona 2003
Quoted: 5 Post(s)
Remove/reinstall outside front door handle
The outside front door handles mount with four bolts, plus one nut that holds the key tumbler mechanism in place. When you are finally inside the door (as per Guavaguy's great pictures) remove only the four bolts and NOT the nut on the key tumbler mechanism. Now from outside the car, jiggle the old door handle and it will come out about an inch and a half, enough to allow you to remove the nut ( and not lose it !) as well as easily pop the little plastic holder off the linkage bar. Then finally remove the linkage, and the handle assy is off painlessly.
Gitmoray is offline
