Hi Radek,
If you have chronic issues with the front brakes, you may have additional issues with the brake system. I'd suggest you get a dial indicator and check for run-out of the disk assembly:
a. Secure and lift the car up, from axle fully up. Put it in neutral.
b. From the underside of the car, locate the dial indicator to be ~15mm from the edge of the disk. Yes, this will be the inside face of the disk.
c. Rotate the wheel by hand and measure for runout, it should measure 0.05mm runout, max. Mark the high spot of the rotor, use a pen market.
d. Remove the wheel, and measure the outside face of the disk. The high spot should be the opposite of the inside test.
If they do not match, Maybe...
a. When you took the wheel off, it released pressure off the disk.
b. Resurface the disk (24mm min thickness), and install new pads.
c. Use a steel brush and clean all joining surfaces off dirt and rust. Brush the wheel inside face too.
d. Remount the wheel and tire. Install the lugnuts in a star sequence pattern, start wit the top lug, do this by hand
e. While the car still up. use a torque wrench and fasten to 79 lb/ft, or 108Nm. This is very important, if you use an impact gun or breaker bar, it may ruin the alignment of the rotor.
f. Check for disk run out one last time. Again to be sure its within tolerance.
If they high spot matches.
a. Look at the mounting of the disk; the two flat head Phillips fasteners, make sure they're not damaged.
b. Check for run out of the hub. It can also be damaged, but unlikely.
c. Look at the disks. If the're too low quality, or they're too thin. They may deform under heavy braking (too much heat).
d. Look at the caliper sliders, make sure they move by hand. If they're hard or stuck, clean and re-lube.
e. Also, be sure the rear drums/shoes are working as expected. If they're loose, all of the braking effort is managed by the front brakes. This will overheat them. I had this issue before, the rotors had a blue hue and the pads had crack marks. I didn't used the parking brake for one year, That's how these self adjust.
MV
