Kia Rondo bulb sizes. - Kia Forum
post #1 of 64 (permalink) Old 03-29-2011, 04:26 PM Thread Starter
Urban07's Avatar
Drives: 2007 Kia Rondo EX V6
Gallery: 1
Just wondering if anyone has a complete list of all the different bulb sizes used on the Rondo. I did not see this in my owners manual like in all my other cars...
Urban07 is offline
post #2 of 64 (permalink) Old 03-29-2011, 04:38 PM
Rev_Pizzaguy's Avatar
Drives: 2010 Subaru Impreza 2.5i Premium 5-door, *old* 2009 Kia Rondo LX 4cyl 2.4L
Gallery: 1
I believe this is correct:
Low Beam Headlight Bulb Size: H11B
High Beam Headlight Bulb Size: H1
Parking Light Bulb Size: 168
Front Turn Signal Light Bulb Size: 2357A
Rear Turn Signal Light Bulb Size: 1156A
Tail Light Bulb Size: 2357
Stop Light Bulb Size: 2357
License Plate Light Bulb Size: 6418
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 168
Rear Side Marker Light Bulb Size: 168
Map Light Bulb Size: 175
Last edited by Rev_Pizzaguy; 04-14-2011 at 09:24 PM. Reason: Corrected parking light bulb
Rev_Pizzaguy is offline
post #3 of 64 (permalink) Old 03-29-2011, 05:08 PM Thread Starter
Urban07's Avatar
Gallery: 1
Cool, is the map light the same size as the center dome lights?
Urban07 is offline
post #4 of 64 (permalink) Old 03-29-2011, 06:44 PM
PLP
PLP's Avatar
Quoted: 315 Post(s)
Nope.
The map lights are 175 (stronger version of 168 = 5W), while 175 is 10W, although base is same.
Dome light is festoon 31 mm (I think) or 35mm. I think these are 7W or so.
Trunk is same. Festoon.
USA - paid, repair manual
Europe - paid, repair manual
PLP is offline
post #5 of 64 (permalink) Old 04-01-2011, 11:28 PM Thread Starter
Urban07's Avatar
Gallery: 1
I am questioning the bulb size of the pinky sized bulb that lights up in the headlight when the parking lights are on this can't be a 2357A its the bulb below the high beam I believe.
Urban07 is offline
post #6 of 64 (permalink) Old 04-01-2011, 11:34 PM
PLP
PLP's Avatar
Quoted: 315 Post(s)
you are right
it is 168. I assume you are talking about the small one inside high beam reflector. The same one (168) is in the side marker - the orange one, on the side of car, and also in rear lamps.
Actually, the front turn signals are indeed bi-filament (7/28W) but the lower (7W) one is not connected to anything.
BTW - thanks for the pics.
PLP is offline
post #7 of 64 (permalink) Old 04-02-2011, 09:59 AM Thread Starter
Urban07's Avatar
Gallery: 1
I thought it had to be a 168 bulb...I just changed out my license light bulbs to LED bulbs they are amazing compared to stock made them look dingy yellow..the plan is to change that front 168 bulb to an LED bulb as well.
Urban07 is offline
post #8 of 64 (permalink) Old 04-02-2011, 10:21 AM
PLP
PLP's Avatar
Quoted: 315 Post(s)
I changed all 168s with LED. I am waiting for 15 SMD 5050 LED panel for trunk light, and probably will replace dome lights, too.
I changed map light with 20 SMD 5050 LED panel to test how it works. It may be too bright, though. Besides, that panel was too big to fit inside there.
PLP is offline
post #9 of 64 (permalink) Old 04-02-2011, 10:54 AM
Gallery: 1
What 168 LED bulbs did you get? Do you have a link?
post #10 of 64 (permalink) Old 04-03-2011, 10:29 AM
PLP
PLP's Avatar
Quoted: 315 Post(s)
eBay...
168
5-LED Car Light Bulb Lamp 158 Super 194 T10 168 SMD W23 - eBay (item 180531692387 end time Apr-07-11 06:53:00 PDT)
festoon
2 Dome 3 SMD LED Festoon Interior Bulb light 36mm White - eBay (item 370485603742 end time Mar-19-11 18:21:24 PDT)
light panel
Light Panel 20SMD LED 29-42mm Dome Interior Festoon 12v - eBay (item 250792559227 end time Apr-20-11 20:08:59 PDT)
And some pics...
Maybe it is not so obvious from them, but the map light (driver side, 20 SMD 5050 LED panel) is very bright and strong comparing to stock light bulb. I think I will switch it to 9 SMD. Will see...
For comparison both are on. The color is very hard to present as cameras will pick up white balance. I defined it based on some off white light, but still - it is not perfect.
License plate: festoon 3 SMD LED.
Headlight - compare the colors. Low beam is 4300K HID, while the LED (168 base) is 5 SMD 5050 LED at about 6000K. Used the same white balance.
ID:	7812   Click image for larger version
ID:	7813   Click image for larger version
ID:	7814   Click image for larger version
ID:	7815   Click image for larger version
PLP is offline
