Key sticks in ignition - Kia Forum
post #1 of 14 (permalink) Old 03-13-2011, 10:32 AM Thread Starter
Drives: 2007 Kia Rondo
I have a 2007 Rondo and occasionally I can't remove the key after shutting off the engine. This has been going on for about a year now. I just took it back to the dealer and of course it wouldn't do it there. The dealer said if he can't see the problem he can't fix it. I understand his point, but I still have the problem. Any help out there?
JRFisher is offline
post #2 of 14 (permalink) Old 03-15-2011, 10:48 PM
KingFatty's Avatar
Drives: 2012 Optima SX Tech/Premium; 2008 Rondo EX V6 7-seater
Can you rotate the ignition when the key sticks? Or is the key stuck in the ignition, such that you can't rotate it and also you can't remove it? Is it like a mechanical grip holding the key in, or is it like there is something sticky inside the ignition like honey?
KingFatty is offline
post #3 of 14 (permalink) Old 03-15-2011, 11:13 PM Thread Starter
The key won't rotate to the position that allows you to remove the key.
JRFisher is offline
post #4 of 14 (permalink) Old 03-16-2011, 10:30 PM
KingFatty's Avatar
Maybe the steering wheel locking mechanism (I assume the Rondo has one) is malfunctioning? Are you able to turn the steering wheel to see if it unlocks the key rotation? Does it only happen when the steering wheel is at certain positions?
post #5 of 14 (permalink) Old 03-16-2011, 11:05 PM Thread Starter
When it happens, moving the steering wheel doesn't help.
JRFisher is offline
post #6 of 14 (permalink) Old 03-17-2011, 09:09 AM
conwelpic's Avatar
Drives: 2016 Soul SX - Caribbean Blue
Gallery: 38
Quoted: 397 Post(s)
have you tried spraying some cleaning oil into the lock? You sometimes get something similar happening on regular exterior door locks on a house. Also sounds like the tumblers are not lining up properly.
conwelpic is offline
post #7 of 14 (permalink) Old 03-17-2011, 11:17 PM Thread Starter
I guess I should have stated at the beginning that I have tried all the obviuos tricks. The doggone thing will work for days and then it just won't rotate to the position that allows your to take the key out of the slot. Wiggling the steering, restarting the engine and moving the car a little, LPS in the key slot, using another key to help push the mechanism in all the way, probably 3 or 4 more that I can't think of right now. Then, all of a sudden, it will come out. It's like it has a mind of it's own.
I was real disappointed in my trip to the dealer. They said sorry, if it doesn't do it here, we can't help. They didn't take anything apart or even attempt to troubleshoot.
JRFisher is offline
post #8 of 14 (permalink) Old 03-18-2011, 07:06 AM
Supacabby's Avatar
Drives: 2014 Kia Soul, 1.6hdi auto, in Mixx trim, White over Powder Blue
Gallery: 9
Quoted: 3 Post(s)
2 things:
Graphite dust in the lock not anything like oil, dirt sticks to oil but not graphite!
Have you tried making sure the gear selector is well & truly in Park? Sounds silly but sometimes this can have the same effect you're describing.
Owned 5 Carens as cabs, 3 x Mk2's & 2 x Mk3's & a Kia Magentis 2.0, all diesel & all worked hard for their living! Now got a 2014 Soul 1.6hdi auto in Mixx trim.
Supacabby is offline
post #9 of 14 (permalink) Old 04-05-2011, 01:35 AM Thread Starter
I looked on KGIS and found a wiring diagram for the ignition key solenoid. I took the upper steering column cover off and could see the connector to the solenoid but couldn't reach it. After working my way under the dash, I was able to disconnect the connector for the solenoid. The key hasn't been a problem since. I realize that the key can now be removed while the car is in drive but I'm an old guy. All my old cars were like that.
JRFisher is offline
post #10 of 14 (permalink) Old 04-05-2011, 06:32 PM
Drives: 2008 Rondo LX - 2011 Forte EX
Gallery: 5
Nice Work! Glad you were able to resolve the problem to your liking.
Tony_K is offline
